Worn clutch pedal pin
Old Apr 23, 2006 | 06:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Worn clutch pedal pin
I've purchased a used brake/clutch pedal set for a 4-speed conversion I'll soon start. It's in great shape except the pin on the clutch pedal that the rod attaches is a bit worn.
I can't find a replacement pin,..plus the old one is welded on and would likey have to be ground and drilled for removal.
What's the solution here?
Thanks in advance,
Wes
Old Apr 23, 2006 | 06:26 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I had the same problem! I dis-assembled the pedal assembly and drilled out the old pin from the back side. I picked up a pin at Home Depot & welded it in from the back side.
Old Apr 23, 2006 | 09:32 PM
73, Dark Blue 454
Vetteman,..thanks for replying.
What exactly did you purcase from Home Depot that worked?
To Worn clutch pedal pin
