BB buildup, just one more big decision left...
Previous post: http://forums.corvetteforum.com/show...teardown+today
With the help of a local performance engine shop I've made some pretty good progress with putting together a good combo for a strong street performance motor. Here's the combo:
The block has been bored 0.030", decked & align honed
Stock crank
Eagle I-beam connecting rods
SRP forged pistons, 26cc dome
AFR 305 aluminum heads, as cast (CR should be around 10.2:1)
Hydraulic roller cam, custom grind (Specs TBD)
Exhaust will be headers w/ dual exhaust out the back
As you can see the one major item missing is the intake. Once that decision is made we can go ahead and pick the cam specs (ok, so maybe there are two big decisions left
). I know the intake issue has come up many times, but I'd like to know what you guys think would work best with this specific setup. I know the Torker II fits under the stock hood, but with my 3.08 gears it seems that an intake designed for midrange performance would be better suited to this buildup. What about the performer (not performer RPM) with a drop base air cleaner, or would that be too small? If this were your motor, and you wanted to stick with the stock hood, what would you do?
).BigBlockk
Later.....
So how does the LS-6 intake compare to my stock LS-5 intake? Any thoughts on how it would compare to an Edelbrock Performer Intake?
...all other components should be matched to the camshaft, including compression ratio, heads, intake, exhaust, rear gearing, etc..
(If you want to keep your 3:08 rear end, and want a "performance" cam shaft, you might want to consider a Richmond 5 speed. know Keisler is a forum sponsor, but I think their 5 speed, an overdrive 5th gear, will mean you'd need something like, say a 3.73:1, etc rear end)
Bashcraft - thanks, guess I missed your post somehow.
That actually raises another question though. The AFR 305's are rectangular port heads. Pretty much all the intakes I've mentioned, or seen mentioned thus far, are available only in oval port. How much of a no-no is mixing head and intake port type?
Am I correct to assume that using a rectangular intake with oval heads is a bigger no-no than using an oval intake with rectangular heads?
On the other hand, using a rectangular port intake on oval port heads will have major sealing issues, along with the obvious port mismatch.
"choked off" both units. The LS-5 was a 496" stroker, the LS-6 is a 454", both were cast iron headed units. Both intakes seem to a be of a "low" design, evidently for hood clearance. I would say just about any decent aftermarket intake would be a better choice. Thanks, Gary in N.Y.
P.S. Neither unit showed any gain when ONLY headers were factored into the program. Both units made identical power, respectively, with the factory exhaust manifolds. We've just recently begun a program testing "extrude-honed" exhaust's for 100% stock appearing cars.
Based on what I've heard here I think I'm going to mention the Performer (despite the mis-match in port shape) or stock LS6 intake to my performance shop guy. If I remember correctly, he's planning to run the choices though a PC simulator so the results should be interesting.
Just thinking out loud here but, as for the Torker II, I'm not sure it's going to suit my needs. Sure, it will give great top end, but at the expense of low end and mid range power. With my 3.08's I just don't think I'll be using all that top end. Zwede has a dyno run posted on his homepage showing his motors performance before and after installing the Torker II. It does a nice job up top, but low & mid range (<4,000 RPM) took a fair hit which is where I expect to run 90% of the time.
Anyway, I'll see what the performance shop says tomorrow when I bounce my thoughts off them. On a side note, they were scheduled to balance my rotating assembly today!
