Does this type of fuel pump actually exist?
Old Apr 23, 2006 | 11:04 PM
PartTimeGenius's Avatar
PartTimeGenius
Default Does this type of fuel pump actually exist?
I have an '80 with a ZZ3 and I'd like to run a better (performance) fuel pump on it, but I can't seem to find any that match these requirements:
1) mounts like the stock unit
2) non-electric
3) has a provision for the return line - every performance pump I've looked at has an inlet and an outlet but no provision for the return line.
P/Ns and links are always appreciated.
Old Apr 23, 2006 | 11:21 PM
big_G's Avatar
big_G
Summit and Jegs have High Performance fuel pumps that work with a regulator. Get a regulator that has a return port.
http://www.summitracing.com
Old Apr 23, 2006 | 11:31 PM
MsVetteMan's Avatar
MsVetteMan
cap the return line........make life easy.......Twist an oversized nut in it, then clamp it off with a hose clamp.
Old Apr 23, 2006 | 11:40 PM
BLACKHORSEVET's Avatar
BLACKHORSEVET
Would this work?
www.racepumps.com
Old Apr 23, 2006 | 11:42 PM
big_G's Avatar
big_G
I want one of those...lend me a few bucks?....
Old Apr 24, 2006 | 01:31 AM
enkeivette's Avatar
enkeivette
Yeah, you can run a regulator that has a port for a return line after the high performace fuel pump that has no regulator. But you don't really need a regulator unless you have excessive psi. I have a carter high flow pump and it makes 5 psi, my Demon can take 7 psi. I just blocked the retrun line off with a vacuum plug. The high performance fuel pumps just bleed off the excessive pressure.
Old Apr 24, 2006 | 08:24 AM
ylose's Avatar
ylose
Originally Posted by BLACKHORSEVET
Would this work?
www.racepumps.com
Appears to be a nice possible alternative to running/relying on an electric one!
Old Apr 24, 2006 | 08:57 AM
TonySinclair's Avatar
TonySinclair
OMG...Bubba lives!
Old Apr 24, 2006 | 11:36 AM
panchop's Avatar
panchop
Its a nice peice of equipment. I have one on my BBC but haven't run it yet. Looking forward to seeing how it works. For the cost,i hope it works great.
Old Apr 24, 2006 | 02:45 PM
MsVetteMan's Avatar
MsVetteMan
Originally Posted by TonySinclair
OMG...Bubba lives!
Actually that suggestion came from this forum, and it works quite well with the new style fuel pumps.
To Does this type of fuel pump actually exist?
