Bought new motor, now what?
There was a lot more to the motor than advertised. Here is what I got:
350 bored and machined .030” over
383 Summit stroker kit which included
3.75” stroke cast crank
Summit stage II rods
Keith Black pistons
Chamfered bearings
Melling oil pump
Also,
all gaskets
Holly fuel pump
Shiny timing chain cover
Heavy duty engine stand
Camshaft and hydraulic lifters: type unknown
Misalaneous parts from original setup
Everything is assembled. I just need to slap on heads, intake and a carb, and I should be ready to spin my wheels. This is my first motor. My original plan was to build a motor from scratch, but I came across this, and I couldn’t resist. Since I am a virgin, where should I go from here? Should I start looking for heads? Is there any kind of prepping I should do before I go any further? Also, is there any way to identify the cam without measuring it?
Also, I don’t understand everything in the description from the machine shop. Here is what it says:
Bore V8 – Think I got this one figured out….
CL Block – Clean?
IN CAM B - ? Install cam… B? Balance?
MACH BLK – Machine Block… for clearance maybe?
MINPRESS – Something to do with the cylinders or crank?
--R/R RODS--
Engine Bearings – Installed engine bearings
EXP PLUG – not sure what exp stands for
Thanks,
Jim
CL Block – Clearance Block ( for 383 )
IN CAM B - Install cam brearings
MINPRESS – Pressed on pistons ?
EXP PLUG – Expansion plugs, 3 in oil galleys and 1 in back of cam
You need to find out what pistons are in there so you can determine the compression ratio and you also need to know what cam is in there before you go any further.
as far as the cam, i am going to email the seller, and if i cant figure it out that way, are there any castings on the cam?
