400ci Vs 383
[Modified by xrated, 2:22 AM 8/21/2001]
If I had it to do over again I would have probably just bought a crate motor from Bill Mitchell hardcore racing. He uses his own block that has fixed the problems of the 400. He is able to bore and stroke it out to 427 cubic inches and beyond. You get all the performance of a big block with the wieght of a small block. What could be better. Not to mention warranty and dyno tuned before shipping. Its more money to go the route of a crate 400 plus motor but not that much more. That is of course if you are comparing to building a stout 383. With Scat crank, forged rods, forged pistons, internal balancing, roller cam, aluminum heads yada yada yada.
Hope this helps and let us know what you decide.
You are correct in thinking that the cost to build a 400 is the same as a 350. Long rods and good heads make for very powerful 6000 ish rpm motors.
Remember (and this should be a rule on this forum) that overdoing a buildup doesn't hurt, BUT it doesn't help (and it's a hell of a lot more expensive too). I should talk, I got 4340 H beams in my 6500 rpm 450 hp small block
I say by all means spend a couple hundred bucks (or more if necessary) and some time and find a nice 400 block.Rob
Unless you are lucky, most production 400 blocks are going to need to be overbored and honed, probably align-honed and decked, and if used in a high-performance applicaiton, you may wnat to add splayed caps. Adding splayed caps and ARP studs can easily cost you $500 for the caps, bolts/studs, and machining. Boring/honing with torque plates and gaskets can cost you over $200, align-honing another $150, and decking around $100. So you could easily spend another $1000 getting a used $200 SBC 400 block up to snuff, $1200 total. What you end up with is a used block that's already been overbored at least once and features thinned, weaker deck surfaces, and main bearing webs and bulkheads. For the additonal $300-400 it seems worth it to me. And if you ever need to refreshen the motor up, more than likely, you'll end up having to take a production SBC 400 block .060" over which is typically not recommended, and in alot of cases you end up with very thin, unstable cylidner walls. Some of the better, high-performance oriented machinists won't even overbore a production SBC 400 .060" becuase they know how thin the walls get.
I'm certainly not saying everyone needs a $1700 aftermarket block, but when you consider the big picture, they may be more economical in the long run and you end up with a much superior foundation for building a very powerful and reliable high-performance motor.
Chevy High Performance just built a 355 based on a late-model (1-piece main seal) Caprice motor that came with a stock low perf. roller cam. They rebuilt the shortblock with normal good 350 parts, replaced the cam with a GM HOT cam (with the original roller lifters and spider assy), installed a new timing kit, Vortec iron heads (reworked with LT-4 springs), and a Performer RPM manifold and a Holley 750. They estimate $2400 for the whole build up, and although they haven't run it on the dyno yet they expect ~420 HP and ~430 lb-ft. Seeing that this is essentially a ZZ430 with a slightly less stout bottom end and Vortec heads instead of Fast Burns this seems reasonable. Imagine the same motor with a 5.7" rod 383 rotating assembly! It's tough to argue with the economics of this pretty basic type of build up whether you go 355 or 383!
[Modified by 69L71, 1:07 PM 8/21/2001]
But if you're going to spend the money, the aftermarket big block with a 4.5" bore is only a couple hundred more.
If you dropped in a forged 427 crank (3.76") in that 4.5" bore block, you would have a 467 cubic inch screamer with a short stroke. I think this is the combo they used in the Can-Am motors in the early 70's.
I feel that this is the perfect motor for a 'Vette.
Now I want one :yesnod: :yesnod: :yesnod:
