Exhaust..Power loss question........
Old Apr 24, 2006 | 09:49 PM
MsVetteMan's Avatar
MsVetteMan
Default Exhaust..Power loss question........
After running open headers for a day or two, the power was unbelievable.........I just got the standard exhaust welded back up at a local shop, and it's a noticeable difference in loss of power. I'm true dual exhaust with no cat. I also lost that sweet lope......any suggestions?
Old Apr 24, 2006 | 10:03 PM
Brettmc's Avatar
Brettmc
What size pipes? Any kinks in them? A lot of backpressure due to mufflers will cut down some hp.
Brett
Old Apr 24, 2006 | 10:24 PM
MsVetteMan's Avatar
MsVetteMan
You know Brett, I don't know, other than they are std. exhaust size. I have only replaced from the cat forward. I'm thinkin' go 3" all the way, where now I'm either 2 1/4 or 2 1/2.
Old Apr 24, 2006 | 10:51 PM
Fubba's Avatar
Fubba
You don't need 3". That's overkill. You do need a 2 1/2" system though if you're running the stock size exhaust. I think stock is like 2". That will help. What mufflers are you running?
Old Apr 24, 2006 | 10:57 PM
MsVetteMan's Avatar
MsVetteMan
I don't know about that. The "Viz" (David Vizard) says rule of thumb for 3" exhaust is about 360hp.......but then again, that's why I'm asking.
The muffs....??? Don't have a clue. They just look like plain ole jain cheapos to me. They have seriously restricted my sound quality, and especially the lope which was quite noticeable with the open headers, and now I can't even hear it.
Old Apr 24, 2006 | 10:59 PM
JoeRags's Avatar
JoeRags
I agree that dual 3" is overkill... plus you'll run into problems with the tranny crossmember. A full 2.5" mandrel bent system is what you should have... with some nice free flowing muffs.
mandrel bent pipes is the key... not the kinked bends that most shops use.
Old Apr 24, 2006 | 11:01 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
cat forward????its not your pipes its your cats that are causing your problem....go to 2 1/2" and no cats and you will be happy
Old Apr 24, 2006 | 11:05 PM
MsVetteMan's Avatar
MsVetteMan
lol.....cats are gone........long gone.....I guess I phrased that incorrectly......
Old Apr 24, 2006 | 11:08 PM
big_G's Avatar
big_G
I had my '68 dyno'ed last year, 383. Almost no difference between open headers (cut-outs) and 2-1/2 exhaust with 40 series Flowmasters. I bet the sound of the exhaust was playing mind games with you...
Old Apr 24, 2006 | 11:09 PM
bobs77vet's Avatar
bobs77vet
perhaps the sounds made it seem faster.....my kids think i'm speeding inthe vette even when i'm going under the speed limit....it took the wife a lot of necking turning to get her to believe me that it just seems like we are going fast
Old Apr 24, 2006 | 11:45 PM
MsVetteMan's Avatar
MsVetteMan
Could be the sound difference. Nothing in the world like actually feeling and hearing the power of open headers on the road. I felt like I was in a 600 hp beast!! Better yet, a Nascar. Maybe it's just the let down of capping the headers off.
I'll work on the fine tuning first, then see where that leads.....until then.......I'm burning some serious rubber......
Old Apr 25, 2006 | 09:09 AM
not a '76's Avatar
not a '76
maybe single 3" exhaust.
dual 3" exhaust is probably good for nearly twice that.
Old Apr 25, 2006 | 09:44 AM
MsVetteMan's Avatar
MsVetteMan
No doubt, that was a minimum........
Direct quote from one of Viz's books....."A 3-inch secondary is only of advantage when the horse power is up past the 375 mark."
But in reading some more he says...."For good all -around street performance, a 2.5-inch secondary works well."
Old Apr 25, 2006 | 09:46 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
2 1/2" is plenty for a true dual system. I'd get two Dynomax Ultra Flow mufflers, these are 'straight thru' design but not too loud... if you're lucky you find them on sale for around $50 each. The local parts store should have these.
Old Apr 25, 2006 | 09:51 AM
Brettmc's Avatar
Brettmc
Ever heard of Doc at Delta Exhaust on Hwy 51 in north Jackson? I've always heard he's the one to go to for a custom exhaust.
Old Apr 25, 2006 | 09:55 AM
MsVetteMan's Avatar
MsVetteMan
Been using the shop up here on 51N in Canton......he's the guys that did my true duals last year!! He's pretty good! He recommended I stay away from the flowmaster because of the resonance factor because the vette sits so low to the ground. No hurry, I'm just fishing now!!
Old Apr 25, 2006 | 11:49 AM
Brettmc's Avatar
Brettmc
So he did the duals you have on the car now? Did you reuse the old mufflers or something? Dynomax Ultra-Flos have darn near the best flow rate on the market. Think about swapping over to them and getting rid of the no-names you have now.
To Exhaust..Power loss question........
Old Apr 25, 2006 | 01:05 PM
MsVetteMan's Avatar
MsVetteMan
Yep, he did the duals on there now. All I did was cut the old collectors off a little back on the pipes so I could get the headers in. The mufflers have never changed. No names on them.
I'll check out the Dynomax, but the Flowmaster super 40's look sweet, without the resonance.
Old Apr 25, 2006 | 01:59 PM
not a '76's Avatar
not a '76
but... flowmasters dont actually flow.
Old Apr 25, 2006 | 02:22 PM
MsVetteMan's Avatar
MsVetteMan
That is the point, isn't it? I noticed that flowmaster listed no specs on their mufflers, wonder why?
I do want flow as the #1 priority, but a good sound to bring that lope back out would be nice as well.
I'll look at the Dynomax......I need about 375 cfm of flow per each side....
