6 Link Strut Rods - Pic
Old Apr 25, 2006 | 02:46 PM
84rzv500r's Avatar
84rzv500r
Default 6 Link Strut Rods - Pic
Gottem back form the powder coaters...
They also dipped my tubular lower control arms so that I can weld on a travel stop and the Sway bar bracket...
Sorry for the PIC quality. Satin Black
Old Apr 25, 2006 | 03:10 PM
Twin_Turbo's Avatar
Twin_Turbo
Do you have a pic of the bracket?
Old Apr 25, 2006 | 03:53 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Apr 25, 2006 | 04:11 PM
stickboy's Avatar
stickboy
Old Apr 25, 2006 | 04:28 PM
JoeRags's Avatar
JoeRags
Think we're all a bit curious...
Old Apr 25, 2006 | 11:18 PM
84rzv500r's Avatar
84rzv500r
No pics of the actual brackets only concept dwgs under my corvette photos. Will post when I get them fabbed up.
I was gonna CNC up some fancy brackets... Posted here... Was talked out of it so I went with a stock lower bracket that can space down with some CNC plasma cut shims to get the best position used 1x2x0.125 rec tubing and sheet. The bottom is done save for a bit of welding on the stock bracket. Spacers for mounts are turned from 316 stainless round stock. componets Pics posted already
For the upper inner bracket piece of the same 1" DOM tubing tapped 5/8-18 welded to a piece of 1/8 steel that will welded to the existing cross member in the correct location.
For the upper outer bracket I have some OTS pieces from S&W that I might use or I can build something from 1/8 or 3/16 flat stock.
I just need to get some time to spend on the project.
Old Apr 25, 2006 | 11:40 PM
LiveandLetDrive's Avatar
LiveandLetDrive
A good friend of mine is from Millerton, PA just across the border from you. Know anyone from down there with the last name Parsons who races Modifieds?
-Chris
Old Apr 26, 2006 | 08:04 PM
84rzv500r's Avatar
84rzv500r
nope... I grew up one valley to the north.
To 6 Link Strut Rods - Pic
