tell me about my engine
Old Apr 26, 2006 | 08:28 AM
soccer794's Avatar
soccer794
Default tell me about my engine
All I've really known about the engine so far is that it was a 454, but now that I'm saving up and starting to plan some mods I'm starting to learn things and they confuse me. Do these parts all match up? Seems like I heard somewhere the LS6 intake was square port and the heads were oval?
Block
3963512....454.......70-76...2 or 4 bolt
Heads
353049.....73-84...oval...OPEN...454, 122cc chamber, 255/119cc ports
Intake
3963569 1970-71 396/402 375 L-78/L-89
454 LS-6, lowrise
Has some kind of a cam in it but fairly mild. Hooker Headers.. HOK-2123-1HKR...1-7/8 size was listed as BB and everyone said they were better to keep torque when they were put on, but now they're listed as SB headers. Has Holley 4160 but it was incorrectly converted to a 4150 and will be replaced this summer. Mallory Unilite Distributor with no vaccum advance and the brown wire thats supposed to be grounded is not hooked up for some reason.
Like I said this is pretty much what PO gave me and about all I know. Do these parts match up or do I need to switch around parts? I know all the numbers on the left hand side are correct, the descriptions I took from mortec and intake description from some random site I found. Thanks a lot.
Steven
Old Apr 26, 2006 | 10:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the pad on the block at the front of the RH head. You will find two numbers stamped there; the engine assembly code and the vehicle code. If you post those, it would provide further information regarding your 454.
Old Apr 27, 2006 | 03:58 PM
soccer794's Avatar
soccer794
I don't have the car with me at school right now, I'm moving out next week. That weekend I'll go back home and get the car. Any idea just based on this info?
Old Apr 27, 2006 | 04:08 PM
luerja's Avatar
luerja
could i jump on this thread for my 454 numbers? I know it is 454 4 speed car from 71.
curious about build information.
Numbers are:
T01I6CPH
C11S108171
Jim
Old Apr 27, 2006 | 08:24 PM
LittleJake's Avatar
LittleJake
Luerja
Here is the break down of the suffix code.
CPH 71 454 Corvette 365 LS-5 4-Spd 4-Brl
CPH 72 454 Corvette 270 LS-5 4-Spd 4-Brl
Old Apr 29, 2006 | 03:04 PM
soccer794's Avatar
soccer794
I can't find this pad you're talking about...any pics? Can anyone tell me anything without these numbers?
To tell me about my engine
