Re: New door locks and ignition switch (Steve Zaino)
It's not bad at all. You will need to remove the steering wheel and the plate that is behind it. You then use a pin of some sort(drive punch) to release it from the column. If at all possible, get a set of locks/ ign. cylinder that use the same key. I bought a complet car set and now have a key for the ignition,another for the doors and yet another for the center storage compartment behind the seat. It sucks
Go to http://www.bokonon.net/corvettefaq/ and look under Suspension and Steering. Depending if you have a standard (non-adjustable) steering column or a T&T, look up the directions and pictures on how to disassemble the column. It will tell you how to remove and replace the ignition lock cylinder.
Once you have the ignition lock cylinder out of the column, I don't know if a locksmith can rekey it to match your doors.
Go check with a Chevy dealer, you can get the lock cylinder to replace the missing one, and a new original key to fit them all. You should only have to install the new one in the door.
Steve,
Why not just buy the door lock you need to replace the one you lost and BEFORE you install it, take it to a locksmith and have it keyed to match your existing key for the other door and ignition.
That way you have the same setup as when it was original and you only carry the one key.
I am doing the same thing on my 68 because thieves butchered the passenger door lock while trying to steal the car.
Change the new lock to match your existing (old) key.
Re: New door locks and ignition switch (ksbunting)
Thanks for the input from everyone.
The only reason I was considering replacing all locks was that the ignition lock is very worn and I can take the key out sometimes and can still turn the ignition.
