How dumb can one be? What next? Help!!
Old Apr 27, 2006 | 03:01 PM
Oldguard 7's Avatar
Oldguard 7
Default How dumb can one be? What next? Help!!
How dumb can one be? I hooked up my inductive timing light positive lead to hot side of my altenator and the negative lead to ground. However I did this with the engine off. When I attempted to start the vehicle I see that puff of smoke accompined with a burnt smell coming from the area of the starter. Uh oh.... Now nothing in my vehicle operates, no lights, radio, nothing. I grabbed my test light to see if I get power to the fuses....they checked out but once again nothing in the vehicle operates?? Again....How dumb can one be?
Did I possibly ruin the entire electrical system or just the starter harness along with the starter??? Help!!!!, Help!!!!!!, and Help!!!!!!!
Old Apr 27, 2006 | 03:08 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
No ...you probably only toasted your fuzable link down by the starter. Hooking up a timing light like you discribe should not have caused any damage??? Unless you had the positive timing light clip shorting the alt. output terminal to alt. case ground????
Bullshark
Old Apr 27, 2006 | 03:31 PM
danno12345's Avatar
danno12345
I agree with Bullshark, I didn't see anything wrong with your setup the way you describe it. That's how I run my timing light too.
Check the fusible link, you can get new ones at any auto parts store.
Dan
Old Apr 27, 2006 | 03:53 PM
72-LT1's Avatar
72-LT1
I've gotten a couple of ugly sparks, when I tried to connect to the alt. After that I just connect it to the horn relay
Old Apr 27, 2006 | 04:40 PM
SIXFOOTER's Avatar
SIXFOOTER
ya have to be carefull with that stud on the back of the alt, more specifically with the red insulator, its easy to short the thing. Fuseable link is burnt, not a big deal, except for tracking down a new one.
Old Apr 27, 2006 | 04:54 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This is how I connect my timing light every time. Keep in mind, I have reclocked my alternator. But you can see that it is easy for you to get the positive into the casing and cause a ground.
Old Apr 27, 2006 | 05:29 PM
Oldguard 7's Avatar
Oldguard 7
From the concensus it appears that I only burnt up the fuse links. I notice these fuse links appear to be of hard plastic similiar to a tootsie roll. Are these old stlye fuse links, i know fuse links on newer vehicles they appear swollen when blown. So it appears that I will not need any new harnesses or starter/altenator. can anyone post other pics of other locations where I can hook up my timing light? I just no longer trust that location anymore.
Old Apr 27, 2006 | 05:31 PM
Q's 68's Avatar
Q's 68
I did the same thing (almost) last week. It turned out that I blew the fusible links down by the starter when I attempted to rebuild my alternator and ended up with a dead short. I rewired and once I got the starter hooked up correctly, I was back in business.
Old Apr 27, 2006 | 09:28 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i agree with the others your fusible links gave up the ghost....i don't see how your timing light did this...
Old Apr 27, 2006 | 10:08 PM
SIXFOOTER's Avatar
SIXFOOTER
on a car with the battery remoted from the engine bay, I have put in a term block like the ones MAD recommends under the hood, usually on the drivers side fender well just to have a convinient place to pick up 12v. It works and is a same place. Use a #10 wire and 30a fuse and your good to go
Old Apr 27, 2006 | 11:05 PM
PRNDL's Avatar
PRNDL
before i discovered the alternator I followed the instructions that came with the timing light: They said to connect it to the battery. I needed long jumper cables to reach the battery, but that's what I did!!
I have an even dumber timing light story if you are interetsted....
Old Apr 27, 2006 | 11:36 PM
freewayflyer's Avatar
freewayflyer
I bought a self-powered timing light. It takes two D-cell batteries. I didn't want to deal with the issue of "How do I connect this thing with the battery all the way back there?"
To How dumb can one be? What next? Help!!
