NOS kits: which one?
Old Aug 21, 2001 | 06:09 PM
ZD75blue's Avatar
ZD75blue
Default NOS kits: which one?
Hi all I'm looking at the Nitrous oxide kits on the market
I have seen a few that are pretty good looking
One that caught my eye was this Sneaky Pete http://www.jegs.com/cgi-bin/ncommerc...6&lastcat=2349
Then this Sniper kit http://www.jegs.com/cgi-bin/ncommerc...553&prmenbr=76
Or should I piece together a kit
My goal is 50-75 horsepower but will probably shoot 100 a few times
ZD
:chevy
Old Aug 21, 2001 | 06:41 PM
ZD75blue's Avatar
ZD75blue
Default Re: NOS kits: which one? (ZD75blue)
ttt
Old Aug 21, 2001 | 06:51 PM
robzr's Avatar
robzr
First of all the Sneeky Pete is really designed for a stealth easy to hide 1/4 mile cheater system. You have to run your setup on the very rich side because the Pete delivers N2O only, no fuel. So it's not a good choice for a driver. You'd also have to refill it all the time as the cylinder is very small.
I have the sniper kit (haven't used it yet though), and some various parts from other kits (cheater solenoids I think). The big difference is the solenoids, which can cost about $80 each if purchased separately. The sniper solenoids are dinky, and make me a little nervous with my overpriced 383. If a fuel solenoid goes out on you, there goes your motor. The bottle seems pretty nice, and the fittings are stainless & aluminum. The better kits probably have slightly nicer fittings. I'd personally go for the Powershot kit which looks like it has beefier solenoids. To get adjustability you just have to buy more jets.
I think Nitrous kits are another example of you-get-what-you-pay-for unfortunately. You might also want to look into the Nitrous Express kits, I think they are cheaper than NOS systems, and a lot of guys like them. One problem with nitrous kits is I don't think they like mechanical fuel pumps too much, because of the varying fuel line pressure from RPM & the pump action. At the least I think you'd want to run a fuel pressure regulator and better yet an electric pump. You also might want to think about a fuel pressure safety switch, which shuts off the nitrous if your fuel pressure drops.
If I hook up my system, I'm going to go all out with a larger stainless fuel line, electric pump, regulator, and even a progressive controller because I run street tires. The only problem is after all that crap, you just paid for half a blower - which doesn't need refills.
later
Rob
Old Aug 21, 2001 | 10:40 PM
gearheadz's Avatar
gearheadz
The new Top Shot from NOS is pretty cool. The unit is concealed inside the air cleaner, the injector slides over the carb stud, its adjustable between 75-150HP and unlike the Sneaky Pete, it delivers both fuel and air:
http://www.nosnitrous.com/HiOctn/Pro...densystem.html
Mark
[Modified by mdsmith, 9:40 PM 8/21/2001]
Old Aug 22, 2001 | 09:55 AM
ZD75blue's Avatar
ZD75blue
I noticed on NOS's web site they dont have any of the carb plate style systems
are these outdated or something?
The Top shot system looks really cool And sneaky (cackling laugh placed here) Just to bad I dont have a holley :cry
Old Aug 22, 2001 | 01:19 PM
Xracer's Avatar
Xracer
I would run the NOS Super Power Shot. It is adjustable from 100 to 150 HP and they make it for the Quad. It is a fairly safe system that will give a nice kick in the pants.
http://www.holley.com/HiOctn/ProdLin...OS/plates.html
Old Aug 22, 2001 | 02:06 PM
RatRacer's Avatar
RatRacer
Default Re: NOS kits: which one? (Xracer)
Just remember that plate systems will NOT work with a stock manifold. It is possible but it require some serious hogging out of the plenum under the carb.
Old Aug 22, 2001 | 02:39 PM
ZD75blue's Avatar
ZD75blue
darn
I was hoping to run a plate if nothing else so either way I'll be around 500 dollars to get it all together (new manifold,kit,bottle,time)
Maybe I should just put in a different rear gear and call it even :rolleyes: (like that'll ever happen)
ZD :chevy
Old Aug 22, 2001 | 02:44 PM
CDaniel525's Avatar
CDaniel525
I have been toying with the idea of NOS for a month now and have decided to go ahead and do it. I am going to go with the NOS Super Powershot cause its adjustable. Like others have said, definitely get the fuel pressure safety switch. I am probably going to go with a electric fuel pump, have a regulator already, and going to add a MSD 6AL at the same time with a possibility of a Jacobs Nitrous Mastermind since I do a little racing. Just make sure you use all the safety sswitches and be safe with it!
Old Aug 22, 2001 | 05:20 PM
gkull's Avatar
gkull
Summit has the 1/2 inch thick spray plate called the NOS Power shot $393.50 with jets from 50-175
I have the NOS ProRace fogger on a tap and drilled Team G manifold with twin stage 125 hp shots for a total of 250. Or if you have a big enough sack you could put on the twin 250 hp shots.
The guy I got it from was breaking cranks and pistons at the 375 hp level In a 425 ci stroker small block.
[Modified by gkull, 3:23 PM 8/22/2001]
Old Aug 22, 2001 | 06:05 PM
ZD75blue's Avatar
ZD75blue
Hey Gkull,
Will I still have to cut up the stock manifold to fit it?
ZD
Old Aug 22, 2001 | 06:13 PM
RatRacer's Avatar
RatRacer
Yes, it's not that it won't fit. The problem is that the spray bars run front to back under the carb. The stock manifold is not open in this area. You would be spraying nitrous/fuel into a large flat area on top of the manifold instead of down into the plenum. Not good.
[Modified by Cam Potter, 4:16 PM 8/22/2001]
Old Aug 23, 2001 | 12:57 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: NOS kits: which one? (Cam Potter)
If I had a stock motor and could not use a spray bar, just install a fogger underneath the air cleaner. Alittle bit of Dremel tool and a bracket, what a cheater system. NOS has the new system, just piece it together.
Old Aug 23, 2001 | 01:24 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: NOS kits: which one? (Budman78)
I have the Edelbrock system and it is about $350 from Summit. It has 50,75 and 100hp jets and looks like a quality setup. Haven't used it yet, still in the back of the car in a box.:( I need to get an external vent for it too since its mounted in the passenger compartment.
Old Aug 23, 2001 | 10:02 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: NOS kits: which one? (Fastguy)
Here's a good deal on a used system minus a bottle. http://cgi.ebay.com/ebaymotors/aw-cg...item=594493774
[Modified by Budman78, 3:05 PM 8/23/2001]
Old Aug 23, 2001 | 10:23 AM
RatRacer's Avatar
RatRacer
I would stay away from a used nitrous system. Not worth the headaches.
Old Aug 23, 2001 | 10:59 AM
gkull's Avatar
gkull
The spray tube is nearly centered in the 1/2 inch plate. I have seen them on unmodified dual planes. If you have concerns I would call NOS tech line and ask.
Right in the summit cat. They have part numbers for both Holley 4 barrel or Quadrajet applications
To NOS kits: which one?
Old Aug 23, 2001 | 12:09 PM
RatRacer's Avatar
RatRacer
Default Re: NOS kits: which one? (gkull)
Not on an unmodified STOCK GM manifold. It will not work without modification. If you are curious why I suggest you pull your Quadrajet off of your STOCK manfold. You will see 2 small primary ports and 2 larger secondary ports that match the throttle plate of the Quad. The areas that separate these ports will interfere with nitrous/fuel distribution. With an aftermarket manifold you will see 2 large ports with a divided plenum manifold or 1 large opening with an open plenum manifold. The plate type NOS system will work with these styles of manifolds. You will need an aftermarket manifold like an Edlebrock etc. to use their plates or you can hog out the stocker to emulate an aftermarket manifold.
Old Aug 23, 2001 | 01:53 PM
gkull's Avatar
gkull
I can't remember the last time I saw a stock intake manifold. Would you refresh my memory because I gave it away years ago but my 79 L-82 aluminum manifold wasn't a 4 hole - was it? :conehead
Dual plane - I was referring to aftermarket aluminum.
[Modified by gkull, 12:01 PM 8/23/2001]
Old Aug 23, 2001 | 09:54 PM
ZD75blue's Avatar
ZD75blue
Now my second (maybe thats my 3rd?:crazy:) question how much of the squeeze can a stock l-48 handle and what happens in the event of a back fire? (throught the carb)
ZD
