Tips for Rebulding the Trailing Arms
Old Apr 28, 2006 | 04:16 PM
11Jake's Avatar
11Jake
Default Tips for Rebulding the Trailing Arms
I took off both rear trailing arms to replace all the bushings and the rotors. But I can not get the trailing arm assemble apart. Do you have to drill out the 4 rivit ends at the backside of the assemble to get it apart.
Old Apr 28, 2006 | 04:37 PM
luerja's Avatar
luerja
No the rivets are actually a bolt that is pressed in. Check the other side near the rotor and you will see 4 nuts attached to the bolts and can only come out with a wrench.
Old Apr 28, 2006 | 04:58 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Remove the parking brake hardware and you'll see the 4 nuts he's talking about.
Old Apr 28, 2006 | 05:29 PM
StingrayDK's Avatar
StingrayDK
Why are you taking the trailingarm apart, are you changing the wheel bearings aswell?
Old Apr 28, 2006 | 05:39 PM
alotaball's Avatar
alotaball
If your just doing rotors and bushings... all you have to to is remove the parking brake hardware.....
Old Apr 29, 2006 | 05:11 PM
11Jake's Avatar
11Jake
Yes, I am going to replace the weal bearings as well. I got the four bolts aout but I still can not get the whole assembly apart.
Old Apr 29, 2006 | 05:47 PM
Red 69's Avatar
Red 69
The bearings are a press fit on the spindel, you will need a press to get it apart. Unless you have the tools to seperate, accurately shim and assemble, the best tip is to send them to Van Steel. I have been there and done that.
Old Apr 29, 2006 | 06:21 PM
11Jake's Avatar
11Jake
So there is no way to get the assembly apart without a press?
Old Apr 29, 2006 | 06:43 PM
RobRace10's Avatar
RobRace10
You need a press tool to get them out and a hydraulic press.
http://www.madvet.com/shop?frame=1.158.1397
Setup Tool
http://www.madvet.com/shop?frame=1.158.1402
Bearing Puller
http://www.madvet.com/shop?frame=1.158.1401
Plus an H- frame Hydraulic Press
http://www.wmhtoolgroup.com/index.cf...ail&iid=139460
After doing this recently, if you don't already have all the equipment, send them to Vansteel or someone who does these on a regular basis.
Old Apr 29, 2006 | 07:00 PM
GTR1999's Avatar
GTR1999
Jake this should help.
http://forums.corvetteforum.com/show....php?t=1229686
If you have tools, an indicator and access to a grinder you can do it. I wouldn't attempt it without a grinder unless you settle for a close job. I prefer to get them dead on.
Good luck let me know if you have any questions.
Old Apr 30, 2006 | 12:26 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
If all else fails... box them up and send to Van Steel.... My problem was resolved!
To Tips for Rebulding the Trailing Arms
