Is a Centerforce clutch worth it?
Old May 5, 2006 | 09:58 AM
CGGorman's Avatar
CGGorman
I've got the DF in my Vette and a factory clutch on my truck. The Centerforce has a smoother engagement and is easier on the leg. My wife can VERY easily drive the Vette around TOWN without worrying about foot or leg fatigue.
Yes, the pedal has a "breakover" feel, like a compound bow. ALL the older cars I've driven had this feel. The only cars I've driven that don't are newer ones, with hydraulic clutches. I prefer the older feel. Just me.
Also agree on the adjustable pivot stud. Just follow the directions, measure carefully, and it will work well.
Old May 5, 2006 | 11:36 AM
Blackened 79's Avatar
Blackened 79
Got a CF II on the '71...smooth as silk. I'd definitely reccommend it.
Old May 5, 2006 | 11:47 AM
Kid Vette's Avatar
Kid Vette
I have a CFII. The clutch pedal feels fine. It is a little grabby if you shift with the revs up. It took a while to get used to it.
Old May 5, 2006 | 12:54 PM
sperkins's Avatar
sperkins
http://www.racepages.com/brand/centerforce.html
Old May 9, 2006 | 07:48 PM
TopGunn's Avatar
TopGunn
Roadster,
I posted a reply the other day and mentioned the pedal vibration and I wasen't happy with the feel. I spoke to Centerforce about that issue and the fact that it gets lighter when the pedal is fully depressed.
1. The pedal change when it's depressed is normal, as someone else here said, something like a compound bow type feeling.
It's not really severe or anything Roadster, just a little different and you get used to it almost immediately.
2. The vibration might be caused by bad geometry of the clutch fork placement in the slot in the bell housing, according to them. They told me to disconnect the linkage and push the clutch fork to the rear of the car as far as it would go and look at the position in the slot. It should be approximately centered. I did and mine was not, it was almost to the rear of the opening, way from being centered. The vibration may be coming from the fact that the throwout bearing is not centered or making flat contact on the pressureplate fingers because of a bad contact angle.
I haven't had a chance to pull things apart yet but in the interest of being fair, my problems might be due to "operator error" and not a bad or poorly designed clutch. If you choose a Centerforce be more concious of the directions than I was
Good luck,
Bill
Edit: here's a pic of what I'm talking about, see how far back the lever is.
Old May 10, 2006 | 12:00 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Originally Posted by norvalwilhelm
I have a centerforce but for $150 difference I would be tempted to try the auto zone one. It can't be that much stiffer.
The little weights on the centerforce at suppose to help but they can also cause a imbalance problem.
Alot complain about their centerforce clutches.
Some people have had good luck with their CF clutches. I didn't. The weights on my CF Dual Friction refused to center causing a vibration problem. I moved on to a McLeod, the vibration is gone and the pedal pressure really isn't that much more than the CF. Just my experience.
Old May 10, 2006 | 12:47 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I put in a CF1 and really like it vs stock... however, now wish I would have done the CF2...
Old May 11, 2006 | 01:18 PM
68vertible's Avatar
68vertible
I'm running a Centerforce Dual Friction and really like the pedal feel. It's got a light weight pressure and very easy to feather when needed, but has a very positive engagement when you want it to.
Old May 13, 2006 | 11:24 AM
MassVette's Avatar
MassVette
I've had the CenterForce Dual Friction setup on the 502 for over 5 years without incident. Works for me.
Old May 13, 2006 | 11:57 AM
harrin's Avatar
harrin
I had a centerforce in my last vette, on this one (also a 71) I went stock, only real difference is the softer pedal in the force, preformance difference is not noticable, however I'm my engine is a stock LS5, which dosn't push out hugh HP
Rick
