Newbie looking for balancer advice
Old Apr 29, 2006 | 02:20 PM
Little Mouse's Avatar
Little Mouse
Default Newbie looking for balancer advice
Hello I have been lurking around looking at the forum for a long time
and it is very addictive. It has been a long time since I have owned
a vette but in the past I had a 66,72,73,78 along with 69,79
Camaros. For now I'm chasing down parts to build a high strung
355 and need a SFI balancer. The TCI rattler, Fluidamper, ATI
all use a different design, I'm leaning toward the TCI rattler.
Opinions please on which design may be the best.
Old Apr 29, 2006 | 08:57 PM
Little Mouse
Any help out there.
Old Apr 29, 2006 | 09:43 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Get the motor balanced and use the street fluid damper. For the price around $150.00 can't beat the bang for the buck. If the motor is balanced correctly that damper should be all you need to run on the street, houstonvett
Old Apr 30, 2006 | 12:55 AM
Little Mouse
Thanks for the reply Houston Vette. The motor I'm building
would be a very poor street engine and would see little
street use. The cam, heads, intake will like to run above
4500 rpm and the engine will need to be in very good balance.
I will need a SFI flywheel and scattersheild so I can keep my
feet intact. Do you think the SFI fluidamper may be better then
the TCI rattler? I'm not to wild on the ATI it seems to be mostly
a revamp of the factory elastomer balancers.
To Newbie looking for balancer advice
