Radio Question
Old May 1, 2006 | 10:59 AM
79-L-82's Avatar
79-L-82
Default Radio Question
I've got the AM/FM/CB. AM Buzzes loud even when engine is not running. FM is very low volume. I don't know about the CB. Is there anything that can be done short of sending for the $500 rebuild. (Not gonna happen) or replacing? Any tips?
Thanks,
Old May 1, 2006 | 11:05 AM
big_G's Avatar
big_G
Sounds like an antenna problem. Make sure it's plugged into the back of the radio securely, and make sure the other end of the cable (above the left muffler) isn't cut or disconnected at the antenna.
Old May 1, 2006 | 09:40 PM
JoeRags's Avatar
JoeRags
sounds like a shielding problem... was your year equipped with ingition shielding? does the buzz on AM correlate with the RPM of the engine?
To Radio Question
