Any other bolts needed?
Old May 1, 2006 | 01:40 PM
adam's Avatar
adam
Default Any other bolts needed?
I'm getting the remaining stuff for my engine rebuilt. But want to make sure I don't miss anything.
I started with a shortblock and will take what else I need from the engine in the vette. But I wanted to make sure that I don't miss something I should get new, etc.
Here's what I am looking to get.
o ARP (or Summit or Ebay) engine bolt kit. Can't decide between Allen head or stainless hex heads.
o Oil pump stud
o Timing cover (alum. or gold iridite) & pointer
o harmonic balancer bolt
Anything I may be missing? Do the engine bolt kits work with the short water pumps we have?
Thanks.
Old May 1, 2006 | 08:43 PM
b71vette's Avatar
b71vette
I used the ARP 12point Stainless bolt/washer kit and they all worked fine.Just use anti-seeze especially if you are going into aluminum. A little extra effort can save you a bunch of pain/time/aggravation down the road. I used anti-seize on everything unless it required thread seal.
Old May 1, 2006 | 10:02 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if you are using headers you may need different bolts for those so they don't bottom out
Old May 2, 2006 | 04:25 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Head bolts, carb studs & bolts, tranny to block bolts, flywheel bolts, clutch to flywheel bolts.
Old May 2, 2006 | 11:07 AM
adam's Avatar
adam
Thanks for the tips.
> to flywheel bolts.
I've picked up a set of head bolts previously. The carb bolts are reuse from
the existing carb. The tranny, flywheel and clutch bolts all are relatively new
from when I replaced the clutch 2 years ago.
Will check the headers - what's the standard flange thickness to ensure the bolts don't bottom out ? I'm going to be using hedman headers. If I don't get the allen head kit, I'll get separate allen head bolts for the headers.
Anything else?
Thanks.
To Any other bolts needed?
