350 to a 700r4 problems
Old May 1, 2006 | 01:57 PM
1978 mayhem's Avatar
1978 mayhem
From: Bedford Iowa, i didn't know spending this much money could be so fun!!
Default 350 to a 700r4 problems
will i need a new driveshaft, and modify the cross member, in my 78?
Old May 1, 2006 | 02:05 PM
Jack71's Avatar
Jack71
You will need to shorten your driveshaft & install a different yoke I believe. You can modify your crossmember, but you may want to buy a new one from bowtie overdrives. I believe a modified stock crossmember holds the 700r4 a little bit higher than stock. This could cause problems with your fan hitting the shroud up front.
Old May 1, 2006 | 02:16 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i used the yoke on the th350 and had the drive shaft shortened, remember you need to take the yoke with you to get the drive shaft balanced, i used a BTO cross member, it did not make the front of the engine sit higher but it did give me lots of room for the dual exhaust, you will need a shift detent kit (although others have skipped this), you need a TV cable linkage kit and an electrical kit to lock up the torque converter. this is a great upgrade
Old May 1, 2006 | 08:18 PM
1978 mayhem
sounds like this may be a pain but worth it in the end
Old May 1, 2006 | 09:43 PM
jdmick's Avatar
jdmick
Here's some pics of my crossmember mod. I bought some 4" square tubing cut it to fit and drilled the slotted holes. I was too cheap to spend the $200 for the Bowtie crossmember plus with sidepipes I don't need the extra room.
I was in too big of a hurry to sandblast and paint the rest of the crossmember.
Old May 1, 2006 | 09:52 PM
bobs77vet's Avatar
bobs77vet
on a scale of 1 to 10 for difficulty i will give this a 6-7....on the same scale for "work" i will give this a 9....its not hard just lots of stuff to do
[IMG][/IMG]
Old May 1, 2006 | 10:14 PM
jdmick's Avatar
jdmick
I would say that's accurate. I had about 2 or 3 days of work into the swap. Dumb stuff like changing the shift interlock mounts and drilling out the old shift detent seem to eat up the most time.
To 350 to a 700r4 problems
