My P/S ram is leaking on my 72. I plan to put on a rebuilt. I've heard there is some adjustment to be made and is tricky. Is that correct? If so, any advice?
There is no adjustment on the ram. The outboard seal is a bit tricky to remove. You can't access the seal on the piston that is inside the assist cylinder.
