L46 vs LT-1
Old May 1, 2006 | 09:12 PM
1996Z15's Avatar
1996Z15
Default L46 vs LT-1
With the horsepower ratings being so close is there really that much of a noticeable performance difference between an L46 and an LT1?
Not knowing for sure but, isn't an L46 very close to an LT1 minus the Holley, Aluminum intake and solid lifter cam?
Old May 1, 2006 | 09:33 PM
Gordonm's Avatar
Gordonm
Having owned both and driven the heck out of both. Yes there is a difference.
Old May 1, 2006 | 09:44 PM
1996Z15's Avatar
1996Z15
Can you expand on that? How much of a difference and how hard would it be to get the L46 to run like an LT1?
Old May 1, 2006 | 10:45 PM
70 LS1's Avatar
70 LS1
The differences are:
LT-1 has high rise aluminum intake manifold with holley carb, transistorized ignition and solid cam with 242/254 .458/.485 116 LSA
L46 has standard cast iron manifold, Rochester carb and hydraulic cam with 222/222 .450/.460 114 LSA
Cam specs from here http://www.geocities.com/MotorCity/D...00/cmspec.html
Old May 2, 2006 | 12:29 AM
StickShiftCorvette's Avatar
StickShiftCorvette
Most sources suggested that the '70 LT-1 was under rated. It's performance is a big step up from a L46 due to the cam, intake, and manifold as stated by 70LS1.
Old May 2, 2006 | 12:48 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
I drove a 70 LT-1 and the way i can descibe it is that it revs like a small block and has the power and pull of my 70 454/390,BUT it handles way better than a Big Block.Very impressed with the LT-1.
Old May 2, 2006 | 12:49 AM
jr9170's Avatar
jr9170
I agree i believe the power was very under rated...JERRY
Old May 2, 2006 | 12:58 AM
BFowlkes's Avatar
BFowlkes
When I bought my 69 L46 the previous owner said it had LT1 heads. But no one mentioned different heads, was he just blowing smoke? How could I tell?
Old May 2, 2006 | 03:53 AM
ETM's Avatar
ETM
What about he 71-72 versions with the lower compression ratio? Are they more comparable to the L46? Ive always had the same question about these two motors and just how different they are.
Old May 2, 2006 | 05:41 AM
dennis's Avatar
dennis
I'd say the cam makes the most noticeable difference. Don't get me wrong, I've had my 70 L-46 for 33years, but its a dog off the line, but never quits on the top end. (love that)
I will never sell it, but for one exception..... a 70 LT1
Old May 2, 2006 | 10:12 AM
70 LS1's Avatar
70 LS1
The L46 and Lt-1 have the same heads, pistons, rods, crank and block.
Old May 2, 2006 | 10:59 AM
sb69coupe's Avatar
sb69coupe
I hate to tell you, but the LT-1 will be just as "doggy" off the line as the L-46, if not even more so. I really love my L-46 and it pulls nicely with 3.55 gears and an M-20. I know it'd pull stronger off the line with a 3.70 rear, but I already turn 3200 rpm at 70 mph and wouldn't want that to be any higher.
Old May 2, 2006 | 12:05 PM
72-LT1's Avatar
72-LT1
The heads are the same, is that correct?. The valves are different sizes I thought.
Old May 2, 2006 | 12:13 PM
70 LS1's Avatar
70 LS1
Valves are the same. 2.02/1.60 for both L46 and Lt-1
Old May 2, 2006 | 12:58 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Both great engines!
I think the L-46 is one of the the most under-rated engines of all time. I had the pleasure of test driving an 69 w/L-46 and she pulled great up to 5500 and had a nice little idle.
I love Q-jets which flow 750,..the Holley flows a bit more, 780. I think the weak spot on the L-46 is the cast-iron intake which was the same part used on all 350 w/ q-jets. I'd get a Q-Jet Performer or Q-Jet RPM Performer and paint it orange.
Add a set of headers and you'd have a great street engine that doesn't often need rocker adjustment, gets better mileage, and has power to spare.
Honestly on the street, would you rather have a torque curve from 1500 to 5500 or 2500 6500? That's basically the difference between the LT-1 and L-46. Nice to have the choice though.
Old May 2, 2006 | 01:02 PM
monza_man's Avatar
monza_man
Love my 1969 L-46. Got the M-21 and 3.70 out back and it doesnt mess around! My 1970 L-46 has the M-20 and 3.55 out back and you can definently notice a difference in the two, but they both have tons of power! (maybe b/c I like to mod the crap out of them)
Old May 2, 2006 | 04:34 PM
jr9170's Avatar
jr9170
My first vette was a 69 350/350 vert.I loved that car,it was fast and handled great.The only thing i did was junk the Q-jet for a Holley,as the Q-Jet gave me nothing but fits.
To L46 vs LT-1
Old May 2, 2006 | 10:12 PM
StickShiftCorvette
The low compression LT-1's have similar peak power to a high compression L-46. The LT-1 still revs higher and has more top speed potential.
Old May 14, 2006 | 03:11 AM
cmb13's Avatar
cmb13
Good thread - I was wondering about the differences myself. Don't forget the cool LT-1 hood and stripes!
Old May 14, 2006 | 01:00 PM
CAGregK's Avatar
CAGregK
The LT1 heads are a little different from the L46 in that they have screw in studs and guideplates which are needed for strong valvespringx and high rpm. Headers for either will make the biggest increase in power. And also the L46 got 2 inch exhaust where the LT1 Got 2 1/2.
