Most of the parts are in so I should be able to crank it in about a week. I still have a few things to figure out. One of which is what do I need for throttle linkage? I have the old throttle cable but I do not have a bracket. What type of setups are you guys using? I am running a Mighty Demon on an AIRGAP intake with a manual trannie so a kick down is not needed. Pics would be great if you have any.
I just put on a Lokar bracket and cable tonight. Smooth as silk and fits perfect. It's a universal cable, so some trimming required, but the hardest part was getting under the dash. Took about two hours with all the in and out and repairs I had to make to the pedal (love those surprises!).
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
There aren't many choices for a 4speed and a Holley or Demon carb. Right now I'm using the stock 4speed bracket which are getting hard to find and $$ if you don't already have one. I'm looking to replace it with the Lokar setup mentioned above.
Thanks guys. Chris I am going to run the same L88 style air cleaner as you have. Do you guys remember the Lokar part #'s that you bought?
