Manifold wont budge!
Old May 4, 2006 | 05:54 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Default Manifold wont budge!
I'm tryin to pop off the original manifold, with one bolt left near the 5 cylinder. I can't seem to find any wrench or socket that can get in that little area. Any suggestions to what to use and why this manifold is on so tight? Something I'm missing?
Old May 4, 2006 | 05:57 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i think your'e dealing with the EGR bolt.. you gotta get it out or you will bust the cylinder head.. don't ask me how i know...
Old May 4, 2006 | 05:58 PM
LeMans Pete
EGR is on the other side. Switch sides, exactly across from the EGR. I know its gonna bust, but the whole thing is locked on, like I haven't taken out a single bolt. Anyone know of an extension that bends? Do they make these?
Old May 4, 2006 | 06:01 PM
grimis's Avatar
grimis
Navigator
Default I've used....
Thin walled, stuby sockets, it has worked for me in the past.
Or try one of thoughs bendable rachets, you can get them at any parts store.
Good luck!
Peace!
Old May 4, 2006 | 06:03 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
youre right.. my bad.. dunno why i was thinkin that...
Old May 4, 2006 | 06:58 PM
lowbuck72's Avatar
lowbuck72
I always keep a drawer of modified tools. One is a 9/16" combination wrench where I ground the heck of it on the box end to make it a thin wall on that side. I originally did it for the cylinder bolts on a Harley shovelhead, but it also works on those small block intake manifold bolts.
Old May 4, 2006 | 07:51 PM
carbster09's Avatar
carbster09
Default Make a tool and use heat!
Shave a socket, etc and use heat, not a little heat either
carbster
Old May 4, 2006 | 09:16 PM
SIXFOOTER's Avatar
SIXFOOTER
I have a shaved down combo wrench like Lowbuck, works great
Old May 4, 2006 | 09:55 PM
joe73vette's Avatar
joe73vette
I've had my cast iron manifold off more times than I'd care to remember, and always had no problem if I used a short 3/8 drive socket, a universal joint and then a 6" or longer extension. Maybe craftsman sockets and universals are smaller than others, but they just fit in there. Joe
Old May 5, 2006 | 12:05 AM
LeMans Pete
I ended up getting it off with a short craftsman 7/16s socket with a short extension. Now its time to get it bead blasted, anybody know anybody in the Raleigh area?
To Manifold wont budge!
