Bleeding brakes and proportioning valve
My brake light on the dash is on. Based on the advice of forum members, I'm going to bleed my brakes. Is the pressure bleeder from Eckler's ok to use? I read somewhere that these aren't too good to use on a Vette. Additionally, how do I reset the proportioning valve so that the switch triggering the brake light goes off? I appreciate the info as I'm going to start bleeding here real soon.
Thanks!
Thanks!
The valve should self center once you have all the leaks out of the system. If it doesn't you could remove the lines on the ends of the valve and use a small drill to recenter the valve.
At least on my '69, there is no porportioning valve, only an imbalance valve to activate the brake warning switch. I have taken one apart and it simply checks that front and rear brake circuit pressures are close to being equal.
Does it ever go off? Does the pedal feel firm? If the pedal feels firm and the light still won't go off, pull the connector off the proportioning valve switch. If it goes off, then the switch may be stuck. If it doesn't, then the e-brake switch is the problem.
Originally Posted by Baytraveler
Ok, I bled the brakes and the light still comes on. What next?
Please let me know.
Thanks!
Please let me know.
Thanks!
