Dang! I still got problems
Old May 7, 2006 | 08:55 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Dang! I still got problems
Put the MSD dist.,6-AL box and coil in Friday and was so happy, the car was running great. Drove it a few miles friday night and a few miles Saturday morning with no problems. This afternoon I changed out the alternator and permanently attached the box to the wheel well. My buddy came by and wanted to see how it would do so of course I obliged him. Pulled out and nailed first, grabbed second and third running around 5,000 RPM and then the engine fell on it's face. Limped home 5-10 MPH re-checked everything. Re-started the car and it sounded and felt fine. So, back out I go with the same result. Pulled the fuel filter (brand new) no problems. I put the car on the lift and found the inlet to the pump was folded (crimped) against the block. Going to replace the rubber line tomorrow. Does this sound like the problem??
Old May 7, 2006 | 09:06 PM
shafrs3's Avatar
shafrs3
Sounds like you might have gotten lucky and shot that trouble between the eyes right off the bat.
Old May 7, 2006 | 09:15 PM
NC C3's Avatar
NC C3
YEP.....bet it runs like it's supposed to once you fix that fuel line.......it's starving for fuel with it crimped like that. Glad you found the prob
Old May 7, 2006 | 09:19 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
The thing I can't explain is why it hadn't done this Friday evening. I drove it several miles with SEVERAL hard pulls and no problems. Why?
Old May 8, 2006 | 04:18 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Your Vette is just Ferkin with ya. Mine does it too.
Old May 8, 2006 | 07:04 AM
Bangkok Dean's Avatar
Bangkok Dean
You win some and you crimp some
Old May 8, 2006 | 07:29 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
YEA!!! It's fixed! Evidently these engines need gasoline to run correctly. AMAZING! EH!
Old May 8, 2006 | 08:10 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Lots of good folks on here. Always seem to have the correct answer. You can't beat it. I would still be driving a white vette with a red hood if it weren't for this place..
Old May 8, 2006 | 08:33 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Old May 8, 2006 | 10:32 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
congrats on getting it running.
To Dang! I still got problems
