I'm interested in replacing my belt driven fan with an electric unit. What salvage yard fan would be the best to look for? Would a late model Camaro unit work, and what would I need to control it?
just about any of them would work, the object is to get the one that moves the most air (CF/M) 2 12" would work, 1 16" would work. Don't let them jam you on the price, I had a guy in a yard here try for $80 for a used fan, He actually looked surprised when I laughed in his face.
Might be worth just getting a new one, with a little digging in here you can find them for $30
A lot of people love the Pulse Width Modulated (PWM) controller made by SPAL. This typw of control varies fan speed with your engine coolant temp. If you use one junkyard fan you will find that you will run it full blast all the time since the junkyard fan may not cool as well as your clutch fan or some newer name brand aftermarket fans.
it could probly be coaxed into working. Any idea how much air it moves? Thats mostly what your looking for
I'm not really sure I would have to research it, but it's out of a V8 Camaro so I would think it should be sufficient. I might look into the late model LT1 fans though, that's what I originally had in mind.
Thanks for the wiring diagram, it'll come in handy!
What kind of switch is that?
