Need help finding the ground for drivers side headlight
Old May 8, 2006 | 09:33 PM
Offbeat Octane's Avatar
Offbeat Octane
Default Need help finding the ground for drivers side headlight
Like the topic says folks, i can't find my drivers side headlight ground for my 77. The bulbs are exceptionally dim on that side and i'd like to correct that!!
Thanks,
Chad
Pictures would be very appreciated, I'm a visual learner...
Old May 8, 2006 | 09:50 PM
DR.Jay's Avatar
DR.Jay
I believe if you open the hood you can see the core support. The ground wire is a black 12 ga with a lug attached to the lower right corner (looking at it from the front). There is also an additional ground wire attached to the surround support metal under the hood surround.
Old May 8, 2006 | 11:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Are you still running the original incandescent bulbs? Sometimes they get really dim as they age.
Old May 8, 2006 | 11:53 PM
Offbeat Octane
just replaced the bulbs, i thought maybe that was the problem. but it wasn't
Chad
To Need help finding the ground for drivers side headlight
