Power valve failure symptoms?
During a long road trip suddenly my car started acting strange. When idling all ok, when slowly accelerating all ok until some 2500rpm, when cruising steady around 2500 all ok. But when slightly starting to add speed from 40miles cruising speed for example it starts hesitating, when adding slightly gas still hesitating more and when adding gas even more it suddenly starts going like no problems...
Of corce it might be some junk somewhere also?...
Could it be rather small junk partly blocking the idle circuit or junk in transition circuit? Or even junk in main circuit...
http://www.bob2000.com/carb.htm
The graphical picture in the middle of the text whoke me up...
http://forums.corvetteforum.com/show....php?t=1368773
Hope this helps.
Good Luck!
KC
