Ball joint flip. Effects on Geometry?
Old May 9, 2006 | 10:52 PM
84rzv500r's Avatar
84rzv500r
Default Ball joint flip. Effects on Geometry?
Ok you suspension guru's as I am preping my Tubular A-Arms for instalation I was looking at the upper ball joints. I remember reading that 3/8-5/8 longer upper ball joint shafts had a positive effect on steering geometry.
If I assemble the ball joint under the A-Arm I get 600 thou more length in the upper ball joint shaft.
My back yard logic says that I get less camber change per unit of wheel travel. Havin the effect of a longer upper a-arm
Correct?
Is this a good thing, bad thing, matter of preference, or irrelevant in regards to a car that will see the 1/8 mile drag strip, some solo action, and the occasional road trip?
Old May 9, 2006 | 11:00 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I just put mine in that way. You want as much negative camber gain under spring compression as you can get. Raising the upper a-arm is supposed to achieve that.
The ball joint extenders add an inch or 2. I don't trust them for racing though.
Old May 10, 2006 | 06:17 AM
MCMLXIX's Avatar
MCMLXIX
Interesting idea. Would adding a 1" spacer to the over under swap be the same as extending the spindle 1.6" ?
Old May 10, 2006 | 07:23 AM
RHD '68 L89's Avatar
RHD '68 L89
No,
the important part of the ball joint is the centre of the ball. you need to raise that up higher to get the effect.
If you just leave the ball joint in the same position and raise the A arm, there is no change in the geometry, the effective A arm is the same. You will get more suspension travel before you hit the bump stops.
Old May 10, 2006 | 09:37 AM
Twin_Turbo's Avatar
Twin_Turbo
exactly, it doesn't matter how many angles you have in the arm, the lie between cross shaft and ball joint pivot center is what determines the effective geometry of the control arm. The only difference w/ the ball joint mounting location is that the arm will be shorter because it angles more however with the tiny amoutn of spacing involved with flipping the ball joint this result is very small.
The only way to do it is extend the spindle or use a taller studded balljoint.
Another way would be to flip the lower ball joint and have a dropped spindle at the same time. This however would require welding up, redrilling and reaming the lower hole the other way around and changes to the steering geometry because of the new steering arm position. You would also need longer lwoer arms because they are effectivly shorter in the horiz. plane being angled down more.
Old May 10, 2006 | 05:16 PM
84rzv500r's Avatar
84rzv500r
got it.
To Ball joint flip. Effects on Geometry?
