What is this for?
Old May 10, 2006 | 11:12 AM
miechesa's Avatar
miechesa
Default What is this for?
Pulled engine out, noticed this cable broke by steering column. Other end goes to transmission. Whats this for? Thanks[IMG][/IMG]
Old May 10, 2006 | 11:16 AM
72LS1Vette's Avatar
72LS1Vette
Are you talking about the cable attached to the lower part of the steering column? That is the steering interlock cable. You are supposed to have to put the manual trans in reverse in order to be able to lock the steering column.
Rick B.
Old May 10, 2006 | 11:19 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I can't tell which cable you are referring to, but I'll take a couple of guesses.
1. If you have an auto & it's a TH400, this has an electric kickdown cable that comes from the switch mounted on the gas pedal, inside the driver's compartment.
2. Could be the locking mechanism that keeps you from moving the gear selector when the key is in the 'Off' position & the steering wheel is locked.
Old May 10, 2006 | 12:02 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
its the key lock cable. it keeps you from removing the key while in gears. lets the key come out when in park on an automatic. Mine messed up and i could not take the key out to i just took the cable off and left it off.
Old May 10, 2006 | 12:45 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
DING DING DING We have a Winner!
Old May 10, 2006 | 03:47 PM
Buzzardz_vette's Avatar
Buzzardz_vette
I always wondered what that was for. It's missing the cable on mine and didn't seem to hurt anything so I never bothered with it.
Old May 10, 2006 | 06:35 PM
VETTEVIC's Avatar
VETTEVIC
Wait till you hit a good bump anf the lever moves. hahaha
To What is this for?
