Installing 1979 rear window (hatch)
Old May 10, 2006 | 11:08 PM
uhvette's Avatar
uhvette
Default Installing 1979 rear window (hatch)
Need some advice on installing the rear window. I found the kit to install the rear glass in the corvette store here. Any body done this before, I know its a large peice of glass but I will inlist the help of a couple friends during installation. I was just hoping I could get some instruction on actually installing the glass. Anything can help. Thanks!
If someone provides directions I will take pics and write up formal easy to read instructions, I have noticed no tech help articles have been submitted for the last year or so. I have some projects on my car that I need to work on and wouldn't mind starting this up again.
Old May 10, 2006 | 11:22 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Sorry I can't help but, the first rear window hatch was I believe in 1982, not sure how you will add this to a 79.
Old May 11, 2006 | 04:28 AM
worship79's Avatar
worship79
Do you have pictures? I have a '79 as well, and installing that hatch has my great interest
Old May 11, 2006 | 09:31 AM
Red 69's Avatar
Red 69
uhvette, back in 78 Cars & Concepts of Brighton Mich along with Chevrolet engineering developed a Hatchback Vette. These first two models produced were the proto type for the hatchback that did not appear until the 1982 models. I understand they packaged some kits, but they did not sell. You can tell if you have the original kit because unlike the 82 hatch, it had chrome hinges. If you have an original Cars and Concepts kit, it may be a rare find. To do the installation you will need the rubber body to glass seal from an 82 model and available from most large vendors if not Chevrolet. I'd suggest finding a boneyard 82 model with the hatch for parts and pictures. Cars and Concepts claimed their kit required a 6 hour installation time and no fiberglass work with minor interior modification. The hatch release was located alongside the drivers seat about shoulder height. An ad for the kit appeared on the back of 79-80 Corvette Fever magazines, but not sure for how many months. That's about all I can tell you about the rear hatch. Good luck with your rear hatch glass retro fit.
Old May 11, 2006 | 03:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
After the 82 CEs came out, there was an aftermarket kit to retrofit the opening hatch to the 78-82 big back window cars. It used GM parts and the back glass from the CE. One of the Corvette mags (Corvette Fever or Vette Magazine, can't remember which) has a how-to article on this swap in a back issue. You can purchase the '82 assembly instruction manual (AIM) and see how the installation was done on the CEs. AIM will also include the original part numbers and installation notes.
Old May 11, 2006 | 09:05 PM
SULLY_PA's Avatar
SULLY_PA
Old May 12, 2006 | 04:05 AM
Aussi chev4fun's Avatar
Aussi chev4fun
Default Ute-
thats a great find would love to get my hands one of these kits cant wait to see your post when compete .
Old May 12, 2006 | 01:43 PM
copter's Avatar
copter
I'm swapping out my original hinges on my 82 CE as we speak.On the 82CE there are mounting brackets up in the top of the body for the hinges so I'm not sure how yours would mount without all that stuff in there from the factory.I suppose your kit has some sort of mount.Let me know how it's going and maybe I can be of some help.
Old May 12, 2006 | 03:39 PM
SIXFOOTER's Avatar
SIXFOOTER
got my interest as well, only thing I don't like about my 81 is no hatch.
Old May 12, 2006 | 05:23 PM
rexx78's Avatar
rexx78
Before you start, make copies of every piece needed, jump through the appropriate legal hoops, then sell it as a reproduction assembly.
A hatch would be very cool.
Old May 12, 2006 | 06:05 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Didn't somebody announce just a few weeks ago that they were making new, stronger hinges?
Old May 12, 2006 | 11:16 PM
82MDVette's Avatar
82MDVette
Someone did have a post about their hinges they were fabricating from billet. The CE stelle hinges stretched over time from the pressure of the gas struts pushing the window backwards when in the closed position.
I just met a local fellow the other day with an all original low mileage CE and his rear window was pushed backwards at least 1/4 of an inch. This may not seem like a big deal, but it wreaks havoc on the gasket and water leaks!
I have an 82 Coupe, not CE, that was fitted prior to my purchasing it 1 1/2 years ago with the rear hatch. Whoever did the install did a top notch job! Looks factory original, but it does have the chrome hinges.
To Installing 1979 rear window (hatch)
