C4 engine in a 1968
Old May 11, 2006 | 11:58 AM
Danishbanker's Avatar
Danishbanker
Default C4 engine in a 1968
Hi
I am planing a clean up in my engine bay, and I am looking for nice pics of how nice it could look, so any nice engine pics woul be appriciated
As you can see my 68 Vet has a ( 350 HO from 1987 alloyheads ect ) engine, so I would allso like to see any of those engines if possible.
Fanally anyone who has experience with that kind of engines running on carb??
Claus Moeller
Old May 11, 2006 | 02:01 PM
PatsLs1vette's Avatar
PatsLs1vette
So you rlooking for tpi engine pics in a c3?I had a modified tpi setup for the last few years.
http://community.webshots.com/photo/...52841409UTGWjd
Old May 11, 2006 | 02:14 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
so what kind of carb do you have Claus?
i see a single plain intake for sure.
what CFM are you pulling through your carb? square or spread bore?
Here are the 350 HO specs
Horsepower.............................. ..............330 @ 5000 RPM
Torque ........................................ .........380 Ft. Lbs. @ 3800 RPM
Maximum Recommended RPM ....................5500
Compression Ratio ..................................9.1:1
Block ............10105123 - Cast Iron 4-Bolt w/ One Piece Rear Main Seal
Crankshaft ....14088527 - Nodular Cast Iron
Connecting Rods ....10108688 - Forged Steel
Pistons .................12361371 - Cast Aluminum
Piston Rings ..........14089025
Camshaft ....................24502476 - Lift: .435" Int., .460" Exh
Camshaft Duration @ .050"..........................212° Int., 222° Exh
Timing Chain................................... ........14087014
Heads............12558060 - Cast Iron Vortec 64cc Combustion Chambers
Intake Valves .......................... 10241743 - 1.94"
Exhaust Valves ........................................ ..........12550901 - 1.50"
Valve Springs ................................10212811 - 1999 L31Vortec
Rocker Arms .......................................1 0089648 - 1.5 Ratio
Valve Lash ........................................ ...................Zero
Spark Plugs .....................................R44 LTS - Gap at .045"
Ignition Timing ....................................10° BTDC @ 700 RPM
Old May 11, 2006 | 04:51 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Don't have one of those newfangled motors here but I like to keep the old girl clean anyway.
To C4 engine in a 1968
