CF 2 Clutch pivot Ball
I've read here of the need when using a Dual Friction but not CF2. I have new flywheel and CF2, and have verified the correct throwout bearing etc. but have a high pitched pedal vibration at higher rpm's (above 3k), no shifter vibration or anything felt in the car only the pedal. CF told me the geometry for the TO bearing contact angle might be off, to see where the fork comes out of the bell housing, it should be approx. centered. Mine is not and is towards the rear of the car. Everyone I've spoken to so far locally says the standard pivot should work fine for this clutch and thy've never had to use an adjustable one.
Anyone have any thoughts?
Bill
My dimension from the ball face to where ever they tell you to measure to, don't remember right now, was right on. So no adjustable ball was needed.
Bernie
I was just out looking at it, took the boot off so I could see inside....even though the fork doesn't exit the slot in the bellhousing in the center, I can see the TO bearing touching the PP fingers and it really looks like it hitting it squarely. It is difficult to see in there for sure but I don't know, this whole things sounds fishey. I'm wondering if the TO bearing is bad.
Bernie, do you mean the ball wasen't seated in the depression for it in the fork?? I didn't use a mic on the flywheel, I layed them side by side on a flat top and put a straight edge across them and they looked equal, old and new, but they could have been slightly off. Flywheel was GM for this engine (ZZ4) that others have used sucessfully. Not sure with this clutch though.
Man I hate to take this whole thing apart again!
Bill
Does this look like a bad angle??
Bernie
Let's see, doctor says take 1 pill every 6 hours, buddy (bench racer) says take 1 pill every 4 hours and double up on Sunday.
Who you going to trust??
I didn't see you picture before I posted. If the slave were installed, you could better tell about the angle but it does look ok to me. another thing that could cause that vibration is having the throwout bearing too close to the pressure plate springs where it actuall touches. Any vibration would transfer thru the pressure plate thru the throwout bearing and fork to the pedal. I just realized you probably do not have a hydraulic system. Have you tried adjusting the linkage at the fork in our out a little at a time to see if the vibration goes away?
Who is a bench racer?
Bernie
There's a ton of free play in the pedal Bernie, and the return spring on the linkage keeps the TO bearing away from the fingers by a long way.
No problem on the comment on the TO bearing. I was really diligent about putting it in correctly, they included a picture with the clutch and I made sure I followed it so I'm pretty sure the springs are in the right place. I do remember the thing didn't look centered on the fingers but they said it's made that way.
I'll try screwing around with the linkage adjustment but this thing shifts smooth and is absolutely quiet and smooth as a baby's rear end below 3k rpm.
If you have that much free travel, it sounds as if all you need to do is adjust your linkage to get most of the free travel out of the linkage. It also sounds like your clutch is working just fine if there is no vibration when you pull out. I wouldn't pull the tranny until I did everything I could to get the slop out of the linkage. Just one question though, does your linkage have a lot of wear in the pivot joints and does it have a spring that keeps it tight when you aren't depressing the pedal. A weak spring, worn linkage, as well as, your linkage just needing adjustment could cause your problem.
If you are not concerned about keeping it original, you should really consider going to a hydraulic setup sometime. Easy to install, no adjustments, no linkage to wear out; just a suggestion.
Bernie
No wear in the pivot points, the clutch fork is pretty new and the rod is brand new last year. Yes I do have the spring on the rod that keeps the TO bearing away from the fingers when it's relaxed. Anyone riding in the car would never know this is happening, it's strictly in the clutch pedal like a high frequency vibration, like a vibra-peen engraving pencil on the bottom of your foot. You take off in 1st and it feels perfect. If you shift under 3K rpm there's no problem. But if you jump on the gas and bring the rev's up and shift at 3-4K, you can really feel it in the pedal. The shifter is smooth as silk.
If it isn't pouring out tomorrow I'll adjust a bunch of the free play out and see what happens and let you know.
Thanks for the reply's.
Bill
That angle relationship might be a cause of some problems but I'm not convinced it's the cause of mine. The Vette shop that helps me out sometimes, has been putting these things in for several years without changing pivot ball lengths. He always installs a new one and a new fork but never changes the lengths.
I hate to say it but it looks like a weekend on my back again pulling this thing apart. I am definately not happy.
Bill
What I found was the pilot bushing was turning in the back of the crank. The OD measured .010 smaller than when it was new. In fact when I pulled the transmission the bushing fell out!
When I installed this thing I put it in the freezeer overnight and still had to tap it in with a rod so it was a very tight fit. It's a NAPA long style bushing and is non-magnetic. The leading edge has a huge countersink so tapping it in did not crush the ID and the ID still measures about .591.
I do remember having to pull the transmission in the last 1/2" by evenly tightening the transmission bolts, even with the clutch depressed it was still snug.
This is a GM crate motor with a GM bellhousing off my old motor and it dropped right on the alignment pins. I'm going to get a dial indicator and check it for concentricity but I can't imagine why it should be off.
So far no-one I've talked to has ever heard of this before (lucky me) but I'll post my results.
Bill
