Speedo clicks & the needle jumps
Old May 11, 2006 | 03:29 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Speedo clicks & the needle jumps
Noticed today, while driving, that everytime the speedo makes a clicking noise, the needle jumps about 20-30mph higher. The clicks happen about every 10-15 seconds. Does the cable need replacing or lubing?
Old May 11, 2006 | 03:54 PM
mandm1200's Avatar
mandm1200
I would give a lube job. On my 76, the cable pulled out from the speedometer end, not the transmission end. I believe there is something like a clip you push on and the cable will come loose. When installing it, I could not get the cable to insert into the transmission without unhooking it from that end.
Old May 11, 2006 | 04:27 PM
Bob Onit's Avatar
Bob Onit
Originally Posted by mandm1200
I would give a lube job..
To Speedo clicks & the needle jumps
