Another Qjet question.
Old May 12, 2006 | 01:26 PM
RagTop69's Avatar
RagTop69
Default Another Qjet question.
On the first start up of the day my Vette won't fire. I have found that, if I remove the top of the air cleaner and then try to re-start the car, it fires right up. It works every time. I have begun to just pop the hood and remove the air cleaner lid as a standard cold starting procedure. Once the car is warmed up it will start up with no problems. I'm thinking things like the choke is creating a flooded condition that is aided by removing the air cleaner lid and providing more air....or....the air cleaner base is somehow interfering with the operation of the choke and, when I remove the lid, the choke is freed up to operate normally? Any other theories or ideas on what might be wrong with my carb?
Old May 12, 2006 | 07:29 PM
BigBlockk's Avatar
BigBlockk
The top of the air cleaner is binding the choke blade. Get a thicker filter. I had the same problem with my '70 when I first got it.
BigBlockk
Later.....
