Brake proportioning valve pt 2
Old May 13, 2006 | 08:51 AM
Baytraveler's Avatar
Baytraveler
Default Brake proportioning valve pt 2
Ok, I've bled the brakes twice and stomped on the brake pedal over and over trying to get the proportioning valve in my '79 reset. The brake light on the dash will not go off. I double checked the e-brake switch by holding it down manually. Do you think the valve itself is bad? If so, is it difficult to replace? It definitely is in a difficult place to reach! What do you all think? Please let me know and thanks again for the advice.
John
Old May 13, 2006 | 09:11 AM
SIXFOOTER's Avatar
SIXFOOTER
do you know which side it shifted to? If its the front, crack a break line on he rear and push the pedal wown til the light goes out. or switch it the other way around.
Old May 13, 2006 | 09:20 AM
Baytraveler
Would that be the same as say opening the bleeder valve in the rear and mashing down the brake pedal? If so, what's the difference between that and bleeding the brakes?
Old May 13, 2006 | 10:31 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Those valves get pretty gunked up over the years, you shoulda see the jello that was inside my '69
To Brake proportioning valve pt 2
