ackerman geometry
Old May 13, 2006 | 11:46 AM
canadian73's Avatar
canadian73
Default ackerman geometry
i'm trying to learn more about steering systems and i know a lots of you guys , especially road racers , could probably help a lot . from the little i know , the ackerman is used to let both wheels turn at different angles when turning and is a matter of the spindle angle versus the centerline of the car . so my question is , if i draw an imaginary line from my spindles , say 20 degrees , to the back of the car , and these two lines crossed at the exact center of the differential housing , than the ackerman angle would be o.k. ? if so , do we have to change the spindle angle each time the wheel base of a car is altered ? some of that stuff probably seemed very basics for you but a lot of us needed your lights .
