Torque flywheel
Old May 13, 2006 | 02:43 PM
Lilfur's Avatar
Lilfur
Default Torque flywheel
I am putting engine back together, and don't have a manual that tell me what to tighten things down to. I would like to know in Ft. Lbs. what to tighten the flywheel , exhaust manifolds , intake manifold??? Is there a torgue chart that I can find like maybe some where on the internet? By the way this is for a BIG BLOCK.
Old May 13, 2006 | 04:01 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I can double check later but I think the flywheel is 65 with blue thread locker, stock exhaust manifolds to head are 25ftlb and my intake was 30ftlb.
Old May 13, 2006 | 04:42 PM
c3dreamer's Avatar
c3dreamer
Here is some information that will help you:
1. Intake manifold bolts: 30 Ft-lbs
2. Exhaust manifold bolts
a. 1968-1977 Vettes: 20 Ft-lbs
b. 1968 - Up: 20ft-lbs outer bolts, 30Ft-lbs inner bolts
3. Flywheel mounting bolts:
a. 327,350 c.i. : 60 Ft-lbs
b. 427,454 c.i. : 65 Ft-lbs
Good luck!
PS Check Haynes Repair Manual for Chevrolet Corvette 1968-1972, Chapter 2, p 2A-2, edition 1999
Old May 13, 2006 | 08:46 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
http://www.boxwrench.net/specs/chevy_bb.htm try this link
Old May 13, 2006 | 09:26 PM
73jst4fun's Avatar
73jst4fun
Originally Posted by 2th farmer
That's a good web site. I just installed a new engine and didn't pull the THD 400 so I used special torque convertor bolts from Jegs and blue locktite. There was no room to use a torque wrench so it was grunt power....
To Torque flywheel
