Tach cable chatter
Old May 13, 2006 | 11:36 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Tach cable chatter
Brand new cable (less than 70 miles) but it really makes a racket. Didn't notice it untill I put the MSD dist. in, yet the position of the cable is very close to where it was on the stock (with a 90 degree fitting) dist. Probably within a few degrees. When the cable is straight out it is very easy to turn but, when I put it close to the position on the dist. it becomes kinda hard to turn by hand. Is the cable in too much of a bind or does it need graphite lube? If so, how is the easiest way.
