How do I remove old window tint
Old May 14, 2006 | 10:54 AM
terry714_us's Avatar
terry714_us
Default How do I remove old window tint
I want to remove the old window tinting that is on my '78. Does anyone know how to do this in a way easier than using a hammer and chisle?
Old May 14, 2006 | 11:03 AM
TonySinclair's Avatar
TonySinclair
Old May 14, 2006 | 11:05 AM
vncruiser's Avatar
vncruiser
Tony.....You forgot to add a LOT of water!
Reid '72 T-top
Old May 14, 2006 | 11:06 AM
c3dreamer's Avatar
c3dreamer
Originally Posted by TonySinclair
Good summary!
Old May 14, 2006 | 11:07 AM
Twin_Turbo's Avatar
Twin_Turbo
Tony LOL
Ususally if you peel one corner off you can pull the entire tint off no need to start scraping w/ a razor blade.
Old May 14, 2006 | 11:29 AM
LittleJake's Avatar
LittleJake
If your car has the defrost strips on the rear window be careful around these areas (if your asking for your daily driver and not your Vette).
Old May 14, 2006 | 12:01 PM
mrvette's Avatar
mrvette
Originally Posted by Twin_Turbo
Tony LOL
TT, maybe in your cooler climate, but here in Floirda that tschit bakes itself on that glass, it's nearly impossible to remove...gotta use a razor and some solvent crap, it's that bad....
bought a used Saturn for my daughter some years ago, and to get it through Maryland inspection, the tint had to be removed....it was a capital BITCH....
GENE
Old May 14, 2006 | 12:18 PM
Twin_Turbo's Avatar
Twin_Turbo
My car came from Kalifornia and had tint on it when I got it, it was pretty sticky but the tint came off pretty easily, the adhesive however, that's another story, I had to use some pretty potent industrial cleaner to get it off
Old May 14, 2006 | 12:33 PM
OldCorvetteKid's Avatar
OldCorvetteKid
I remove window tint with an inspection sticker scraper with razor blade in it and high strength rubbing alcohol...the 85% stuff from your local pharmacy...does the job.
Old May 14, 2006 | 01:55 PM
Meh's Avatar
Meh
That elbow lacked some grease on it...
Anyway, a sharp razor and soapy water in a spray bottle works great, alchol too. The film will usually come up once you lift the corner. The adhesive needs a little liquid on it, then scrape until you don't fell the blade catching on anything. Work in small sections and it's not bad.
Old May 14, 2006 | 02:32 PM
terry714_us
Great info guys but I found that if you spray the glass with 'Simple Green' and then take a plastic garbage bag cut to the shape of the glass, place the bag on the inside of the window and presws it against the glass so that it is semi-adhered, trapping the solvent between the bag and glass; the tinting becomes soft and is easier to remove.
Old May 14, 2006 | 10:07 PM
blueonblue's Avatar
blueonblue
When I had my truck windows tinted, the installer advised that it could be removed with a solution of amonia and water. Hope this might help.
Old May 14, 2006 | 10:44 PM
69vette66's Avatar
69vette66
just spray the inside with water then put a garbage bag over the window, just make sure it is in the sun or it a little warm. after about 10 minutes the tint peels right off, no film left on, all including glue comes right off.
good lluck
Larry
Old May 14, 2006 | 11:33 PM
Crazy81's Avatar
Crazy81
Try some 3M genral adhesive remover. Best stuff I ever found for removing tough glues. I get mine at the local auto paint supply.
Old May 15, 2006 | 12:36 PM
C3 4ME's Avatar
C3 4ME
I've been able to do it on the past with just Windex and a razor blade. It was not hard at all, and I know it was a professional installation.
Old May 15, 2006 | 01:18 PM
comp's Avatar
comp
what if that doesn't cut the glue and if it's on the back window ??? don't want to scrape off the rear-de-frost?????
Old May 15, 2006 | 02:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Ususally if you peel one corner off you can pull the entire tint off no need to start scraping w/ a razor blade.
Depends on the type of tinting used. The crap on my door glasses and big back window (Jeepers!!! It was purple?!) would not peel and defied everything I used to attempt to strip it. Razorblade scraper was the only thing which worked.
Old May 15, 2006 | 09:42 PM
mrvette's Avatar
mrvette
Yeh, I"m saying from my limited experiences with it, that tschit is all over the map depending on age and mfgr and glues....
and with super intense sunlight, I swear it changes into some sort of female gorilla snot on her monthly time....
GENE
To How do I remove old window tint
