Headlight housing support bracket pics
Does anyone have some good detailed pics of the bracket, with emphasis on the front mounting tabs.
I figure I can either carve the tabs out of aluminum or fab something out of sheet metal and it will work just as well.
I just need some good reference pics or diagrams to get started.
Thanks.
Let me know if you need close-ups of the ends, I have the lights here sitting next to me.
Wow, that was quick! This forum is great.
If you don't mind, I'd like some closups of the ends from directly above and directly from the sides (I know, picky sum-b****) so I can get a better perspective on how to out bubba bubba.
More pics, these have been repaired (riveted + epoxy + jbweld + sheet metal to hold the broken tabs/ends on) Holes at the end of arms are supposed to be threaded, mine were drilled out.
but in fact, get a friend who can TIG weld, they are aluminum castings, and if done right, will be strong as dirt....
GENE
Thanks a bunch. Those will get me on the right track. I don't drive it much at night and didn't really care much about it until I recently noticed that it was starting to separate the header bar from the fiberglass.
Thanks again
