bigblock intake
Old May 16, 2006 | 01:08 PM
javier's Avatar
javier
Default bigblock intake
does anyone have an idea on what type of aluminum intake i can use with a holly carb on a 71 454 oval port and use my stock b.b. hood thanks for any info
Old May 16, 2006 | 03:41 PM
Todbo's Avatar
Todbo
edelbrock Torker II will fit under stock hood
henderjl's Avatar
henderjl
Default Big Block Manifold
The Edelbrock Torker II will fit. Get the choke horn milled off your carburetor and use a drop base air cleaner. If you haven't gotten your carburetor yet, you can get one all set up with horn milled from http://www.aedperformance.com for about the price of one not set up from Summit.
Old May 16, 2006 | 04:44 PM
javier's Avatar
javier
thanks henderjl i will look at that site and see what i can find i have a stock dual snorkle does this mater thanks again
Old May 16, 2006 | 07:38 PM
Simmo's Avatar
Simmo
Ive got a discontinued Holley Street dominator singhle plane. I prefer it over the Torker II as it has longer runners. I extended the runners further into the plenum. With a big drop base 3" aircleaner, no choke horn I can even use a half inch spacer and fit under 1970 hood.
Old May 17, 2006 | 06:23 AM
javier's Avatar
javier
thanks Simmo for the input every bit helps
Old May 17, 2006 | 06:52 AM
Big Dan's Avatar
Big Dan
What is your engine, specs rear end ratio,and how do you plan to use the car (street, strip, ect). I dont recomend the Torker II intake for most. The rpm range is 2500-6500.
Old May 17, 2006 | 08:48 AM
javier's Avatar
javier
Hey Big Dan i basicaly want a street driver with a little power i have 10 :1 compress. and a 520 comp magnum cam i wont be driving it every day as i am doing a frame off rest. but i do want to drive as many weekends as the weather will allow its a 4sp i believe my rear axel ratio is in the 308 to 356 range i could not read the suffix i did a quick turn on the wheel to drive shaft but it was to uncomfortable thanks for your time
Old May 17, 2006 | 01:34 PM
javier's Avatar
javier
ttt
Old May 17, 2006 | 02:38 PM
Les's Avatar
Les
Javier,
The Torker II will fit as has been stated. Just a heads up- Edelbrock techs said it would improve power output enough to drop .2-.3 from 1/4mile ET but warned me that it would also be likely to cause a stumble as you accelerate from idle. One of our big block members, Zwede if I remember right, had exactly that problem & couldn't tune it out. I just wanted you to go forth with your eyes wide open. Good luck.
Old May 17, 2006 | 05:18 PM
Big Dan's Avatar
Big Dan
I have 3.08 to 1 ratio and 4sp with 454 and was not happy with torker II. I am replaceing it with 390 hp 427 oem manifold, but it is a spread bore carb monting only.
Old May 17, 2006 | 05:55 PM
javier's Avatar
javier
thanks to all for the input, Big Dan are you using an aluminum or cast intake I thought that the 427 were square port and 454 were oval if Im wrong I will look for a 427 intake thanks
Old May 17, 2006 | 07:08 PM
73 LS-4's Avatar
73 LS-4
The intake he was refeering to was the 68-69 corvette 427 390hp or L-36 intake which is a large oval port aluminum intake with a spreadbore pattern. I've run one for a few years now and I do like it. They are kinda rare so expect to pay between 200 and 300 bucks for one, your power range on them is about 1500-5300 rpm. I have a torker 2 in my basement but I wouldn't trade my L-36 for it, the L-36 is a better street intake on a stock-mild 454.
Pat Kunz
Old May 17, 2006 | 07:09 PM
Jay M's Avatar
Jay M
I have a Torker II and it seems to work fine. It is a very tight fit! See my sig for dyno results.
Does anyone know if the Barry Grant Tripple D will fit? And if it will perform better than a TorkerII?
If nothing else it sure will look cool!
~Jay
Old May 18, 2006 | 06:44 AM
javier's Avatar
javier
I will definately will start looking for a 427 intake thanks for the help
Old May 18, 2006 | 06:57 AM
Big Dan's Avatar
Big Dan
The 68-69 intakes the only oval ports al intake that I know of . It took me 3 months to find it. The torker II didn't have any power till the 2500 rpm range and with the 3.08 gears it was not a good combination. The other option i was considering was a GMPP intake ( I dont have the # with me) is .5 taller than my torker. I had .5" clearence between the stock open element air cleaner and the hood. If I changed 3"x14" element 2.5" and cuting down or removing the chock air horn I think it will fit. Have you checked the clearence you have now .
Old May 18, 2006 | 09:16 AM
javier's Avatar
javier
I have no idea about clearance yet my body is of the frame
To bigblock intake
