Powder coated side pipes?
Old May 16, 2006 | 05:41 PM
sperkins's Avatar
sperkins
Default Powder coated side pipes?
Anyone ever heard of taking the black Hooker side pipes and headers and having them powder coated? I would think that powder coating would hold up better than a thin layer of paint. Any thoughts?
Old May 16, 2006 | 05:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Powder coating is a heat-applied process, which generally requires about a 400F temperature to set. There are high-temp powders which undergo a chemical reaction at the setting temperature and then won't re-melt until a much higher temperature, but I've never used them. Standard powder coat will remelt at the working temp.
Best bet is to call a powder coating shop and talk to them. If they don't work with high-temp powders, they should know someone who does.
Old May 16, 2006 | 05:57 PM
Joe45's Avatar
Joe45
Hello,
I am familiar with powder coating.(20+years). As a general rule of thumb, powders are removed from metal substrates that require re-coating at 800 degrees F. Not quite sure of header temps. but I personally would not use powders in this application. Companies are now offering high temp powders. I would ask questions around specific chemistry, i.e. epoxy,hybrid, etc. Each chemistry has its benefits and downsides for an application. Most important with powder is that the quality of the coating is very dependant on the substrate and its preperation. Ask any potential supplier alot of questions. Hope this helps.
Old May 16, 2006 | 05:59 PM
OldSchool's Avatar
OldSchool
What about Jet-Hot? With the forum discount, it is reasonably priced...
Steve
Old May 16, 2006 | 06:15 PM
js292's Avatar
js292
I just powder coated so stock c4 exhaust manifolds, Look in my pics
Sorry about that, there wasn't one in my photos but I found it in my files here
Old May 16, 2006 | 06:16 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
All I saw was 4 pics. None were of the exhaust manifolds. I would like to see them also.
Old May 16, 2006 | 09:07 PM
sperkins's Avatar
sperkins
Steve
Does Jet-Hot do black?
I thought they only did the "ceramic" color.
Old May 16, 2006 | 09:15 PM
cchristo's Avatar
cchristo
[QUOTE=js292]I just powder coated so stock c4 exhaust manifolds, Look in my pics
Have you ran them yet? I'd be concerned that the coating might start to melt again.
Old May 16, 2006 | 09:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sorry about the slight hijack...
js292, what is the outlet diameter of those headers?
Old May 16, 2006 | 10:05 PM
roger's 2937's Avatar
roger's 2937
I had my headers "ceramic coated" and they still look like new.
I've tried Jet-Hot with no luck, however ceramic coating on the side pipes works great and comes in silver, black or titanium.
Old May 16, 2006 | 11:12 PM
js292's Avatar
js292
[QUOTE=cchristo]
I haven't run those yet but I have on a motorcycle exhaust and it is holding up really good. It's a high temp coating (I believe high silicon content)
I'm Batman Sorry about the slight hijack...
No problem, I thought I had the pic there (I saw you posted before I could correct myself ). The outlet is 2.5, they are stock C4 manifolds I cut the air tubes off and welded up then powder coated w/ a high temp powder.
Old May 17, 2006 | 12:40 AM
sperkins's Avatar
sperkins
Where did you have this done? Estimated cost?
Thanks...
Old May 18, 2006 | 02:54 PM
OldSchool's Avatar
OldSchool
From Jet hot website..
COATING REQUESTED: (Please select one)
Sterling™ (silver finish/1,300°F)
Cast Iron Gray (1,300°F)
Matte Black(1,300°F)
I've tried Jet-Hot with no luck, however ceramic coating on the side pipes works great and comes in silver, black or titanium..
Roger's 2937, What problems did you have with Jet-hot? I am thinking of having mine coated by them.
To Powder coated side pipes?
