panel adhesive
Old May 16, 2006 | 08:47 PM
zigvs's Avatar
zigvs
Default panel adhesive
Where do I find the adhesive that holds on the panels or is it just fiberglass?Also How does the bonding strips work?Thanks
Old May 16, 2006 | 09:46 PM
big_G's Avatar
big_G
The bonding strips work by creating a lap joint for adjacent panels. The panel adhesive I use is made by Evercoat, part number 994. It can be bought at auto paint supply houses.
Old May 16, 2006 | 10:14 PM
CF6873's Avatar
CF6873
The bonding strips are bonded to the back side of adjacent panels. One half of the strip is bonded to one panel and the other half is bonded to the adjacent panel. You would bond the strip to one panel first and clamp it. Then when it is cured fit the next panel and usually you can hold it in place with tape while it cures. I also use the Fiberglass Evercoat adhesive.
Old May 16, 2006 | 11:21 PM
JonnHeather's Avatar
JonnHeather
3m 8115. Comes in a tube, no mess, very long set time. Incredible strenght. Lifetime warranty...
Old May 17, 2006 | 12:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What about spot repairs? My driver-side door is loose in one corner - maybe 3"-4" total separation from the frame.
Old May 17, 2006 | 02:09 AM
comp's Avatar
comp
there is a past thread on this ,,,search doesn't work for me
Old May 17, 2006 | 04:40 AM
J. Swisher's Avatar
J. Swisher
another vote for 3m, being in a tube makes it very easy to make spot repairs like a door, but you need to ensure that a clean rust free surface is present
Old May 17, 2006 | 08:36 AM
76vette1's Avatar
76vette1
Does the 3M or Evercoat adhesive work between the fiberglass panels, like the fender and inner panels?
Old May 17, 2006 | 09:14 AM
big_G's Avatar
big_G
Yes, as long as you prep. the surface and blow out the dust prior to bonding.
Old May 17, 2006 | 03:08 PM
rrhodes4's Avatar
rrhodes4
I bought some of the 3m adhesive yesterday. The dual tube cartridge cost around $45.00 but the gun that you must have cost $140.00. I was lucky enough that the place I bought from it is going to allow me to bring it back when I am done. That is as long as it still looks new. The documentation that came with the adhesive said that it was a 24 hour cure time but you could work with the parts after 2 hours.
Old May 17, 2006 | 03:32 PM
mr. creosote's Avatar
mr. creosote
I used the Vette Panel Adhesive a couple months back with success (so far) on a fender well panel. However, I have to admit that I made quite a mess in my garage and had that stuff stuck all over me by the end of the day...
Old May 17, 2006 | 09:21 PM
zigvs's Avatar
zigvs
Default thanks
I'm on it
Old May 17, 2006 | 10:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Damn...that 3M stuff is expensive for just gluing down a small separation at the corner of a door. Is there anything that comes in smaller quantites? Maybe just some good ol' epoxy?
Old May 18, 2006 | 03:55 PM
rrhodes4's Avatar
rrhodes4
I have used J B Weld in areas. I didn't even have problems when applying paint over it.
Old May 18, 2006 | 10:24 PM
76vette1's Avatar
76vette1
Thanks for the info.
To panel adhesive
