need help with trans cooler lines
Old May 17, 2006 | 11:11 AM
rastadr's Avatar
rastadr
Default need help with trans cooler lines
i think bubba had the lines wrong. starting from the 700r4 can someone please tell me which line is out and return and correct routing into radiator and auxilliary cooler. thanks ahead of time
Old May 17, 2006 | 01:37 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I don't know which is which, but i'm not sure it matters. It's probably better for the fluid to flow from the bottom of the cooler to the top to prevent bubbles from becoming dispersed and smaller, but I'm not sure that air in this sytem is a problem. Otherwise, it really wouldn't matter.
Old May 17, 2006 | 02:04 PM
jdmick's Avatar
jdmick
On a 700r4 the bottom is the output and the top is the return. Like CA says, I wouldn't worry about it. The only reason to need to know would be if you're using a directional inline filter.
To need help with trans cooler lines
