Anyone running a ZZ383??
I know the ZZ383 is only 425hp advertised but I am thinking about buying just the shortblock and installing AFR 195s, a nice lil hyd roller, about .550 lift, 230/240 duration@.050 on a 110-112lsa. I think I will need about 500 crank HP or 400 rwhp to run mid 11s. I don't want it so radical that the vacuum stuff doesn't work or have overheating and hot start issues. I still want to run AC also. Been looking at builders and crate motors..still shopping around.
What are you performance minded fellas running for powerplants and drivetrains? What ETs?
I know classic vette guys don't normally run their cars at the strip but I am curious as to what these things will do. This should be interesting
more in the range of 4.11s to obtain your goal. the new C6 ZO6
with the 427 a 6 speed trans to work with good traction for street
tires runs low 12s high 11s and its not as heavy as a 71.
I don't want to run too much gear(4.11) since its only a 3 spd and will get some freeway action.
I am hoping someone is running a ZZ383 as it comes from GM and see what they are doing. I am guessing 12.30-12.50s in a early C3 with an auto and converter.
Sounds to me that your car is gonna haul ballz if it was going 110mph with the old motor..
If you are drag racing than an auto is the way to go. Much more consistant. On the street I prefer to row my own gears. 1st gear is steep but when you shift at 65 to 7000 rpm I'm doing about 45 when I shift to 2nd. I like the gear setup.
The LS1 is a completly different motor and much stiffer on the bottom end. I just wanted to lower end so I did not have to worry about it coming apart. Probably overkill but there is always room for more HP this way.
gyopp Is your 408 a stroked 350 block or just a bored 400 block.
Man thats a really good price for a carb to pan, fully dyno tuned engine. I would imagine without the march pulley setup it would be around $6800 or so...very reasonable. I will call them. I have looked at their website and it didn't have too much on it but...
Does it come with any warranty?
ajrothm Yes, it has a one year warranty. I talked to Loyd(the owner ) about this and he told me that if it takes a year to build the car or month he doesnt care. Just call him when I was ready to start using the engine and they start the warranty then. They will ask you to send any parts that you may reuse or buy elsewhere so that these get installed for the dyno run. No test carb that gets pulled after the run.
They will run it with everything as it will run in the car from the plug wires to the water pump. They will video the run for you and welcome you to visit and watch. After watching this I felt they were not concerned at all about breaking the motor. This is the 408 engine they advertise on ebay with the accessories that I wanted and set up for my use.
http://cgi.ebay.com/ebaymotors/408-C...QQcmdZViewItem
This is the base motor they built me. Pricing is as follows:
base engine $4395
hydraulic roller cam upgrade $389
alum water pump $99
chrome fuel pump $69
chrome ps pump $149
chrome alt $169
petronix distrib $199
AED 750 holley $439
flexplate $69
moroso wires & looms $99
march kit $840
march a/c comp $285
crate fee $65
my shipping $155 ( varies with location )
Loyd can get you anything you want but does not care if you want to buy something elsewhere and ship it to them. Thier prices looked reasonable enough that I would have been ashamed to buy somewhere else for them to install.
gyopp- That would be a 4 inch stroke in a 350 block. That is a big stroke for a SB motor. The clearances are going to be extremly tight and you will be close to a water jacket after clearance grinding. They sound like they know what they are doing, but a small base circle cam would probably be needed as would some Hard Block in the lower part of the block.
I just looked at their ebay listing. If they can do al that for 4300 that is dirt cheap. I have way more than that in my motor and I assembled it.
Have they dynoed yours already?? which cam did you go with?
similar-times from a "reliable street-motor" , through the pipes, with a 3000-stall converter and even 3.73 gears might-be asking too-much from a ZZ383 with a cam & heads.....
Maybe but I don't think so. I think that guy's early 80s camaro is a freakin TURD if it only runs 11.50s. Hell its basically a race car. That thing should be running 10.80s. Maybe he just has a mild 383, who knows but....
I have two buddy's with 383s, one is a 70 nova. 383, plain jane Dart iron eagles, small hyd roller, 3k stall and 3.73 gears and the car runs 11.50s@115 through 3" flowmaster exhaust.
The other is a 66 vette, its got a fuel injected 388", AFR 195s, solid roller, doug nash 4+1 tranny and a 3.08 posi and he has been 11.80s@114 on drag radials with 1.70 60's, not power shifting. Car makes 407 rwhp. His mph is a little low for the HP per weight but we chalk that up as slow shifting.
My last old car was a 78 trans am, mild hyd cammed 400 pontiac with 68' gto heads, mildly ported, 3k stall and 3.42 gears and that thing would go 12.0s all day long. Not to mention it weighed 3650lbs
I don't think a ZZ383 crate motor will come anywhere close to 11s as its shipped but with AFRs, good roller cam and tuning, I think it should do it no problem. Guess we'll eventually
