MSD & Radar Detecter
Old May 19, 2006 | 08:29 AM
73383's Avatar
73383
Default MSD & Radar Detecter
When I had my 73 down doing the 5spd install I took the time to do several other things. One of those was to install a MSD modual, coil, cap, and rotor in my HEI dist. Now when I start the car the Passport detecter goes crazy. It will alarm on x band then alarm on laser continuosly. Has anyone else had this problem and is there a way to fix.
Dennis
Old May 19, 2006 | 08:53 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't want to hear this. I just bought a passport radar detector for the vet, haven't tried it yet but I run 4 msd boxes under the dash.
I sure hope yours is an issolated problem.
Old May 19, 2006 | 09:17 AM
73383's Avatar
73383
Norval
I havn't hooked up the box yet, only the upgrades to the dist. I moved the detector to the durango this morning and drove to work. It worked fine.
Dennis
Old May 19, 2006 | 04:19 PM
73383's Avatar
73383
ttt
for the left coast
Old May 19, 2006 | 05:15 PM
norvalwilhelm
Originally Posted by 73383
Norval
Dennis
Mine is in my Dodge truck right up behind the mirror. I want to move it to the vet when I go on my weekly runs to some cruise night. Usually Brian/Vettr runs out front with his detector protect Doug and myself
Old May 19, 2006 | 09:15 PM
chris75stingray's Avatar
chris75stingray
i just put in a probillit dist. with a 6a box and now i get a lot of radio interfearance that i never got before
Old May 25, 2006 | 08:28 AM
73383's Avatar
73383
Update
I emailed MSD and recieved a reply. The suggested I put a coat of dielectric grease on the plug wire connections, rotor contactl and coil contacts. Although I knew this just would not work I tried it anyway.
To my amazment it worked great, Passport working great and it appears I have better radio reception.
Dennis
Old May 25, 2006 | 09:00 AM
73 red vette's Avatar
73 red vette
Well, mine did the same thing in my 73, just went crazy, so I'm going to have to try the dielectric grease, you say you put it on the plug wires at the dist end and the module as well as the dist to coil plug, right.
got to try that, thanks for the info
Old May 25, 2006 | 10:00 AM
oregonsharkman's Avatar
oregonsharkman
Interesting subject guys....My theory is that with a capacitive multiple discharge system the switching speed is high enough to produce microwaves....this will be very close to the radar frequency band. By putting dielectric grease on the parts you are preventing the waves from propagating....Pretty Slick and good info to know.
Old May 25, 2006 | 10:18 AM
73383's Avatar
73383
yea, I really didn't think it would work. It would set of the laser warning first, then move to the ka band, then back to laser. It was just crazy.
To MSD & Radar Detecter
