Building a 540
Old May 19, 2006 | 05:21 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Building a 540
I am really seriously considering ordering a 540 from Ohio Crank. It is a short deck Merlin block and 4340 stroker crank set up for a blower.
I could get a 571 for exactly the same money but only in a tall deck and that requires me to use spacer for my intake. I have an honest weeks worth of work in the blower intake and don't want to scrap it.
I am trying to take the easy way out
A 540 would replace the 460 I have now and everything would bolt right up, no header problems either or distributor problems.
It would be internally balanced, not assembled because I want to check everything myself.
I will continue to run the blower but the boost will drop because of the extra large cubic inch but I would like 9 to 1 compression because of this.
Anyone have experience with Ohio Crank, any bad feedback??
The company is only 7 hours from my place so I would go personally to the shop to pick up the engine but check clearances before paying.
Any feedback on this would be appreciated???
Old May 19, 2006 | 05:34 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
I have heard nothing bad about them. My only concearn would be an 8-71 is a little small on a 540, even with less boost. Not that it won't work, but a 12-71 would probably be a better fit.
That being said your car will be even more of a monster.
BTW Norval you can run a 572 in a short deck, 4.560x 4.375 or 4.625 x 4.25. With steel rods the 4.375 crank will fit one of the after market blocks just fine.
Old May 19, 2006 | 07:32 PM
VetteLS6's Avatar
VetteLS6
It should beat a ricer, man you guys are power brokers!
Old May 19, 2006 | 07:41 PM
Meh's Avatar
Meh
Sounds good. I could think of a good home for the old motor...
Old May 19, 2006 | 07:47 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Nothing exceeds like excess. Go for it.
Old May 19, 2006 | 10:37 PM
norvalwilhelm
A 871 is actually designed for a 568 cubic in motor or 8 cylinders each with 71 cubic inches. Last year I was capable of running about 12 pounds of boost. With the new heads I have dropped a little boost but haven't pushed it to see how much.
I really want just a 4.500 bore so my cylinder walls stay extra thick. They would put a 588 together for me, short deck and all but I don't want a 4.625 bore. I want a reliable block and I am taking the easy way out with a small 540 Everything and I mean everything is a straight bolt on from the old 460.
I could go bigger in the blower but agian when is enough enough. I think this will be it for me once the 540 is in.
Price a 10-12 or 14 series blower?? They run close to $5000 alone. No I will stick to the 8-71 and hopefully the motor can use everything it can put out.
I will up the compression to 9-1 from the present 8-1 because of the lower boost.
If I run a simple 5-7 pounds of boost with the 540 it will be more then enough power to do what I want.
I will order the motor around the first of August, 3 weeks shop time and drive down and pick it up the end of August and make it my winter project.
I have seen dyno runs in the high 900 horse range with these low boost numbers and it shouldn't be too hard on the motor..
If my motor can take everything the 8-71 can put out I will be happy and should have enough power to put a smile on my face.
Thanks guys
Old May 19, 2006 | 10:52 PM
84rzv500r's Avatar
84rzv500r
A little OT...
Yep 8x71 and it's a 2 stroke to boot. My buddy has antique trucks and I found him a really clean 1973 Ford L9000 twin screw tractor with a 871 Detroit/13 speed.
318 horse and GOBS of torque. She checks in around 20,000 lbs and will twist the frame just blippin the throttle. Sounds just to cool.
That blower looks huge on Norval's BBC, you gotta look close on the Detroit to see the blower in th Vee...
Anyway Norval has the right idea... Way Way to much is ok for now
Old May 20, 2006 | 12:16 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Now we're getting serious!!
You might look into upgrading to one of the Callies cranks. You can also get them with two keyways already cut for blower.
The basic Callies. Eagle, SCAT, SRP stuff is good. I would stay away from the CAT branded stuff and really look closely at the *house brand* cranks and rods because that is what many of them are. You just have to check. Competition Products has some pretty sweet deals on components. if nothing else order one of their catalogs....lots of good stuff in there at good prices.
What pistons will you spec? 4032 or 2618 material? Where will you put ringlands? What rings? Have you studied the Napier style 2nd rings? They will provide great oil control without as much tension.
JIM
Old May 20, 2006 | 12:36 AM
Ironcross's Avatar
Ironcross
If you want boost, it`s very simple. Just change the overdrive to a higher ratio with different pullys. This will give you all the air you need.
Old May 20, 2006 | 07:09 AM
norvalwilhelm
This heats the air too much. By jumping the drive ratio I am getting higher boost but at a price of hotter air. I am running 15% overdrive now and don't want to increase the overdrive anymore.
I will have to just run my present setup on the 540 and see how it works. Who knows what crazy idea I will get next. I keep saying that after the next mod I am going to quit but that day might be way down the road.
Old May 20, 2006 | 07:13 AM
norvalwilhelm
JIM
Jim I don't know enough about the various brands to make serious important selections. I just talked to Ohio crank, read their web site and thought it sounded good.
I asked about upgrading my rods to severe duty and they said at the power level I am looking at it is not necessary.
Pistons? I don't know yet, until I order the motor and really ask specific questions I don't know who's brand.
As for the dual keyways that is a good suggestion. I machined my own dual keyway in my present crank but they can do it so much easier and at the same time machine the fluid damper for the dual keys.
To Building a 540
