removing stuck rims
Old May 20, 2006 | 10:51 PM
Grim's Avatar
Grim
Default removing stuck rims
I have a 1976 corvette that has been through hell and back. I purchased it as a project from the ground up and I do not know much about mechanics, The rims on the car are stuck and I am having trouble removing them. I dont want to damage the rims, but I have tried like HELL to get the off. What has been the best methods to remove stuborn rims.
Old May 20, 2006 | 11:00 PM
MidShark's Avatar
MidShark
Are they aluminum wheels? I have had this problem with my son's S10 Blazer. I just took a crowbar to the inside of the wheel and found something to pry against (maybe the strut rod end?) and gave it a good rap. It popped right off. You can even pry against the tire if you are too worried about the rim.
Rich
Old May 20, 2006 | 11:03 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
brute force is required here...
i have often had to remind my wife that just because i am cussing and throwing stuff, it doesn't mean i'm not enjoying myself.....
Old May 20, 2006 | 11:06 PM
Grim's Avatar
Grim
unfortunately the tire is shredded because of where it sat before I bought it, sat in a driveway for a few years with a flat.
Old May 20, 2006 | 11:09 PM
GDaina's Avatar
GDaina
a jack, jack stands, 2x4 and a sledge is all that's needed
Old May 20, 2006 | 11:12 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Get a large rubber deadblow hammer, and give them a good wack.
Old May 20, 2006 | 11:18 PM
Grim's Avatar
Grim
will the hammers damage the rim, or as long as i dont hit the rim too hard and use padding such as a 2x4 or deadblow hammer, it will be fine???
i have a tendancy to get too involved with the deconstruction and ruin pieces and parts and i am trying to take a more thoughtful approach and be careful to damage as little as possible.
rcread's Avatar
rcread
I'm curious. And then what happens?
Old May 20, 2006 | 11:31 PM
Avette4me's Avatar
Avette4me
small children scatter...
Old May 20, 2006 | 11:38 PM
Grim's Avatar
Grim
thanks for the responces. i'll take a wack at it tomorrow
Old May 20, 2006 | 11:43 PM
Glass Act's Avatar
Glass Act
A rubber/deadblow hammer will not damage the rims, but don't miss and hit the fender....
Old May 20, 2006 | 11:52 PM
GDaina's Avatar
GDaina
Jack up car, place jack stand under car, take 2x4, take sledge, place items under car, crawl under car, place 2x4 by rim, take sledge, whack 2x4
Old May 21, 2006 | 01:25 AM
wnjlt1's Avatar
wnjlt1
take the lug nuts off but leave one nut on with a couple of threads to hold the wheel when it breaks loose. with a rubber / deadblow hammer, hit the wheel backside lip area a few times then rotate the wheel a little and hit it again, repeat until the wheel comes off. good luck
Old May 21, 2006 | 10:28 AM
mkflanagan's Avatar
mkflanagan
BFH
Old May 21, 2006 | 10:41 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Old May 21, 2006 | 02:09 PM
1Z87L8's Avatar
1Z87L8
exact method i have used and it works perfectly
Old May 21, 2006 | 02:27 PM
zigvs's Avatar
zigvs
Its most likely stuck on the center hub.Spray some WD 40 and try what they all said.Also if the car drives,we used to loosen the lugs a few turns and drive it a few feet and hit the brakes a few times.Works like a charm.
Old May 21, 2006 | 10:08 PM
Vettkeeper's Avatar
Vettkeeper
That's how we did it back in the day
To removing stuck rims
