Spal PWM purple wire hook up
Old May 21, 2006 | 12:59 PM
77 vette's Avatar
77 vette
Default Spal PWM orange wire hook up
I'm running dual fans with the Spal PWM controller and relay. I was wondering where the best place is for the orange ignition wires to tap in too? Thanks
Old May 21, 2006 | 01:12 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Old May 21, 2006 | 03:48 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Check your fuse block closely, mine has a lug marked, of all things...IGN.
Old May 22, 2006 | 12:40 AM
71SoCal's Avatar
71SoCal
Initially I ran my orange wires (I had 2 since I'm using the secondary relay too) to the coil since it's ignition switched. It seemed to work, but later I realized that it's not a full 12 volts, but maybe closer to 7 volts.
I ended up running the wires through the firewall (along side my fiber optic lines) to the IGN blade on the fuse block. It's full a 12 volts and it works well.
Good luck...
Old May 22, 2006 | 08:30 AM
pws69's Avatar
pws69
That's where I tapped for power to the Spal Controller and Pertronix Ignition module.
Old May 22, 2006 | 09:09 AM
Hvymtlc5's Avatar
Hvymtlc5
Wired mine to the starter with a temperature control relay. Also wired the second fian to the A/C connector so that if I need additional cooling I can just slide the switch to A/C and the 2nd fan comes on (AC is long gone).
As mentioned above, make sure you pick a source where you get a clean 12 Volts. If you wire off of accesories like the blower, you may get voltage drops and less ummph to the fans.
Old May 22, 2006 | 10:44 AM
pws69's Avatar
pws69
I don't believe the question related to the SUPPLY voltage (which can be sourced from the Starter as you have done or the Junction Block) - it was about the CONTROL voltage, which should be switched (i.e. the IGN terminal).
Old May 22, 2006 | 12:53 PM
Hvymtlc5's Avatar
Hvymtlc5
Thought getting 12volts to the orange wire was the objective. I switched mine with the AC switch to the compressor lead.
Old May 22, 2006 | 05:59 PM
77 vette's Avatar
77 vette
I would like to keep it under the hood If I can. How about the "S" terminal off the starter? I don't have A/C. I think I'll need a fuse to do this.
Old May 23, 2006 | 11:33 AM
Hvymtlc5's Avatar
Hvymtlc5
Did your 77 have A/C? If so the wiring is probably tucked out of the way...there are two wires on the harnes...can't remember whick color (think it was green) to use.
Old May 23, 2006 | 06:01 PM
77 vette's Avatar
77 vette
No a/c that is why I would like to use the "S" post off the starter. Can I do this?
Old May 24, 2006 | 08:15 AM
pws69's Avatar
pws69
No, that's not a good place. Of the two small terminals on the starter solenoid, one only has voltage when you have the ignition key in the Start position, and the other ONLY has power WHILE THE STARTER IS ENGAGED. That's it.
The IGN terminal is you best choice. You can "hide" the wire in and under the looms.
Old May 24, 2006 | 08:43 AM
77 vette's Avatar
77 vette
I thought the coil taps off this post? Oh well looks like I'll run a new wire through the fire wall. Thanks.
Old May 24, 2006 | 12:50 PM
pws69's Avatar
pws69
Yes, in a stock configuration, one of the wires DOES go to the + side of the coil - this provides the full 12V to BYPASS the BALLAST RESISTOR during Engine startup. That's why I stated that there is ONLY 12V there when the starter is actually engaged. The other small gauge connection to the Starter [solenoid] is the wire from the START lug of the ignition switch.
To Spal PWM purple wire hook up
