82 Fuel Gauge Problem
Old May 21, 2006 | 01:38 PM
secrt0007agt's Avatar
secrt0007agt
St. Jude Donor '15
Default 82 Fuel Gauge Problem
My 82 gauge is not working properly, it is not reading the correct fuel level. Is this going to be a "remove the tank" fix? Thanks
Old May 21, 2006 | 01:46 PM
Twin_Turbo's Avatar
Twin_Turbo
no need to remove the tank, you can pull the sender from the top, remove the lid & lid frame, remove the gas bib, undo the lines and the electrical connector and pull it up. You have to rotate and twist it a bit but it comes out as a whole. You need to check if the float does not hang up on the strainer and if the rheostat gives a correct signal. To do this hook up the electrical connector (pull the fuel pump fuse first) and move the float. Have someone check the gauge.
