TIRE SIZES: For my 1969 Stingray???
Old 05-21-2006, 08:18 PM
BOSTONCAMARO
BOSTONCAMARO's Avatar
Default TIRE SIZES: For my 1969 Stingray???
The first thing I need for my Corvette is tires.
I brought it home on four rims is all, we carefully flatbedded it onto my friends ramp truck, using plywood to cushion the wheels.
It has the factory 15 X 8 Rally wheels which I will be keeping, suspension is also stock and will never be lowered or anything like that.
What are the ideal sizes for the car?
I am thinking
Fronts - 245 60 15s
Rear - 275 60 or even 50 series 15s?
For now the car is going into storage, until my Camaro is done, basically just need to have it movable, perhaps at the end of the summer when the Camaro is on the road I will throw a motor in the Corvette.
Thanks in advance for the help!
Tim
Boston Ma
Old 05-21-2006, 08:49 PM
Corz
Corz's Avatar
Cruise-In IV Veteran
255 is the biggest you can go without offset trailing arms
Old 05-21-2006, 08:50 PM
BOSTONCAMARO
will 255 fit all the way around?
255 60 15s?
thanks
Old 05-21-2006, 09:26 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
I saw a 70 last weekend with 255/60s on 8" turbines all the way around and they looked great. Was REALLY close to the trailing arms though. I am going to try them in BFG radial TAs, black side out.
225/70s on 8" wheels =
Old 05-21-2006, 09:30 PM
rihwoods
rihwoods's Avatar
245-60-15's front...255-60-15's rear...
Rich
Old 05-21-2006, 09:36 PM
Corz
Corz's Avatar
255 60 15s?
thanks
yeah, the fronts might rub at full lock though
I've got 235/60 up front 255/60 out back
Old 05-21-2006, 10:14 PM
ajrothm
ajrothm's Avatar
So 255s rub on the front? I really wanted the same size all the way around but don't want tires hanging out of the front fenders either. Want to keep the tire height the same as the 225/70s I'm sporting now, thats why I thought 255s would be good
Old 05-21-2006, 10:23 PM
c69vete
c69vete's Avatar
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I run 245-60-15 all the way around. No clearance issues and I can rotate the tires to distribute wear.
Old 05-21-2006, 10:25 PM
rihwoods
rihwoods's Avatar
I used to run 255's all around on my 78...no rubbing..some rub..some don't...
Old 05-22-2006, 07:22 AM
cruz-n69
cruz-n69's Avatar
Default No rub
I run 255-60's Goodyear Eagles all around and don't have a rub problem anywhere. I have factory sidepipes, which means you lose a little clearance behind the front tires, but still no problem with the 255-60s. It's close, but no cigar.....
Good Luck
Old 05-22-2006, 07:31 AM
ajrothm
ajrothm's Avatar
Good Luck
you have any pics of them on your car? especially on the front.
Old 05-22-2006, 08:17 AM
ralexand
ralexand's Avatar
Default 69 Coupe Tire Sizes
I have stock trailing arms and am running 235-60 15s on the front and 275-60 15s on the rear on 15 X 8 rims with no rubbing. I also had no problems running the same tire configuration with mid 70's aluminum Corvette wheels before I installed the Cragars and adapters.
Old 05-22-2006, 08:43 AM
BOSTONCAMARO
Thanks alot for the responses
For now, I think I will get 245s, but see what I can find used...
The car needs a ton of work, for now, just need to be able to move it around.
Old 05-22-2006, 10:04 AM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
255/60/R15 Firehawk Indy 500s.
Old 05-22-2006, 12:58 PM
gatorbcn
gatorbcn's Avatar
I have 15 X 8 YJ8 "Pace Car" wheels on my '74 with 255-60 15s Eagle STs all the way around. No problems at all.
Old 05-22-2006, 11:11 PM
cruz-n69
cruz-n69's Avatar
Default Here, here
Old 05-22-2006, 11:17 PM
James B
James B's Avatar
I had the same set up...only thing it rubbed was the upper inside of the finders if i hit a dip in the road
To TIRE SIZES: For my 1969 Stingray???
Old 05-23-2006, 12:09 AM
jr9170
jr9170's Avatar
Location: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Received 1,069 Likes on 755 Posts
255/60 15 all around,no rubbing issues.
Old 02-28-2017, 02:34 PM
ddeckles
1st Gear
ddeckles's Avatar
How much clearance between tire and bottom of fender with the 245/60s do you have when you lock your front ? I put 245/60s on my 69 and had exactly a 1/4 inch gap on both sides. I chose to move down to 235/60s up front b/c I just wasn't comfortable with a 1/4 clearance.
Old 02-28-2017, 03:16 PM
Easy Mike
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
DDeckles: this thread is from 2006. You may want to open your own thread.
Quick Reply: TIRE SIZES: For my 1969 Stingray???
